Finding how much heat it takes to vaporize
  • Thread starter Thread starter Skysong12
    Heat
To determine the heat required to vaporize 600g of lead starting at 34°C, the initial temperature change (ΔT) is calculated as 1716°C. The formula Q = mcΔT yields a value of 133,848 J for heating the lead to its boiling point. However, it's crucial to consider the latent heat of vaporization, which must be added to the calculated heat. Additionally, the melting point of lead should be factored in, as lead may not be molten at 34°C, and the heat capacities for solid and liquid lead differ. Accurate calculations require incorporating both the heating and phase change processes.
Skysong12
How much heat does it take to vaporize 600g of lead that is initially at 34°C?
heat capacity=1.3X102
ΔT = 1750°C - 34°C
= 1716 ° C
Q= m X c X ΔT
= 0.6 X 1.3X102 X 1716
=133,848 J
Am I suppose to factor in the change of state? Is there latent vaporization?
You've answered your own question. Think about the analogy of turning water to vapor.
Skysong12 said:
Q= m X c X ΔT
=133,848 J
Yes you are, Q = mcΔT just gives you the heat required to raise the temperature from 34°C to 1716°C.
You just need to use Q=mlvap now and add them.
ΔT = 1750°C - 34°C
= 1716 ° C
Q= m X c X ΔT
=133,848 J
I not sure lead will even by molten at 34o, so you may have to melt it too. ANd is the heat capacity of solid lead and liquid lead the same?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
