Finding I3: Resistance Ratio Calculation
The discussion centers on calculating the current I3 using the current divider rule. Two formulas are presented for I3: one involving R2 and R4, and another involving only R2 and R3. It is clarified that since R2 is not in series with R4, the correct formula is I3 = R2 / (R2 + R3) * I. When R3 is set equal to R2, this formula yields the expected result of I3 = I/2. The consensus confirms that the second formula is the appropriate choice for this scenario.
hquang001
In the figure below, how can i apply current divider to find I3 ?
[tex] Ix = \frac{Rt}{Rt +Rx} I [/tex]
Should it be I3 = \frac{(R2+R4)}{(R2+R4) +R3} I
or I3 = \frac{R2}{R2 +R3} I
hquang001 said:
Homework Statement:: In the figure below, how can i apply current divider to find I3 ?
Relevant Equations:: Ix = \frac{Rt}{Rt +Rx} I
Ok i know the answer,
in this case R2 is not in series with R4 so the second answer is correct
If you set ##R_3=R_2## which of the two choices gives you the expected answer ##I_3=\dfrac{I}{2}##?
The second one
Right.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
