Finding Impulse Transfer Function with Impulse Invariant Method
The discussion focuses on finding the impulse transfer functions of digital compensation links using the impulse invariant method, given a continuous transfer function. The impulse invariant method involves computing a discrete impulse response by sampling the continuous impulse response at regular intervals. The transformation from the continuous domain to the discrete domain is expressed using the z-transform. A key challenge noted is the lack of a specified sampling time, which may require keeping it symbolic in the solution. Overall, the method emphasizes the relationship between continuous and discrete systems through appropriate sampling.
maxiking
Transfer functions of the continuous compensation links are given as follows. Find the impulse transfer functions of the digital compensation links using the impulse invariant method.
\frac{a}{s+a}
I don't know how to solve the problem correctly :cry:
D(z)=Z[D(s)]
d(t) = ae-at
D(z)=\frac{az}{z-e^(-at)}
The idea behidn impulse invariant method is to compute a discrete impulse response, h[n], from the continuous impulse response, h(t), by sampling h(t) every T units of time.
h[n] = Th(Tn)
The discrete impulse response is the z-transform of this quantity. It's troubling that the problem statement doesn't give you a sampling time. I suppose you will have to keep it symbolic as T.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
