Finding Increse in Volume Given Temp, Vol Expansion....
In summary: actually trying to find the volume of the mercury in the bulb, but the volume of the entire thermometer.
Oannes
I am supposed to find the increase in volume, or more specifically how much mercury will rise inside of a thermometer, given the following values. The volume expansion is 1.8 * 10-4/C(degree Celcius). The temperature increase from 30 to 70 degrees F (already converted the temp increase to 22 C). Finally, I am given that the bulb contains .2 millimeters (it actually does not say .2 millimeters of mercury but I assume that is what they are referring to) of mercury and that the tube has a diameter of .2 millimeters.
Increase in Volume(DeltaV) = Volume Expansion * Original Volume(V) * The change in Temp(Delta T)
X = 1.8x10-4/C * ? * 22 C
Volume of a Cylinder = pieR2H
I have so far been able to form the above, however, I am not sure how to proceed in finding the original volume.
I have the diameter so therefore I have the radius, however, I do not have the height and i do not understand how knowing that the bulb contains 0.2mm of mercury helps in finding the answer. I am tempted to try using the amount in the bulb as the height, or even just multiplying the 2 together, however I do not see how that helps me get any closer to finding the volume. Thanks in advance for any help and I feel like I am missing something very simple.
Original Problem Statement:
We want to construct a thermometer using mercuyr. As the mercury in the bulb is heated, it expands and moves up the thin capillary tube connected to the bulb. The symbol used for the coefficient of of volume expansion of a substance due to ta temperature increase is B(sigma). it is used in the following equation: DeltaV = BV(DeltaT)
here, DeltaV is the increase in volume, V is the original volume, and DeltaT is the temperature increase. The value of B is 1.8x10-4[1/degree Celsius]. If the bulb contains 0.2 milliliters and the tupe has a diameter of 0.2 milimeters, how much will the mercury rise in the tube in units of centimeters if we increse the temperature from 30 degrees F to 70 degrees F?
Are you sure that the bulb information was not its volume in milliliters? Or perhaps cubic mm? One way or another you'll need to have the volume of the mercury in the bulb, since that's what's going to be expanding with the temperature change.
Can you share word for word the text of the problem dealing with the bulb and its contents?
I saw that i misread it for millimeters instead of millimeters, but even when I plug that into the eqaution and get .000792cm3 for the increase in volume I don't see how that is supposed to help me get how much the mercury rose. I took the cubed root and got .09205213cm, but that doesn't seem right at all.
Supposing that the bulb itself does not change dimensions (maybe it's made of pyrex glass), and only the mercury expands, where will the excess mercury go? What length of tubing will it occupy knowing its shape?
It will shoot up the tube, but we don't know the length of the tubing, only its diameter. I suppose that possibly the increase in volume (.000792cm3) could represent the height since it is shooting through the tube, but we would have to get the unit in centimeters if it were to make any sense with the Volume of a cylinder. Then again, we are not concerned with the volume, just how much the mercury rises in the tube in units of centimeters. Since I got the increase in volume to be .000792cm3 I suppose that does represent the height once you take the cubed root of it. Since volume is LxWxH essentially. Wati... do i use V = pier^2H and plug in .000792cm^3 as the Volume, and the diameter as the radius to find the height? I think I do... yeah I think that makes sense, since the mercury is shooting into the portion of the tube where the diameter is known.
I think you're starting to put it together. Carry on...
Likes Oannes
Diameter was .2mm convert that to radius which is .1mm convert that to cm which is .01cm, square that which is .0001cmm.
then I take the volume over the radius^2*pie (.000792cm3/(pie)(.01cm2)) and get 2.52cm. Thanks a bunch for the help and also thanks for guiding me along, self-discovery is a beautiful thing. I love these Eureaka moments almost as much as I love the ones I have in my programming classes. Cheers much thanks mate.
You're very welcome.
Related to Finding Increse in Volume Given Temp, Vol Expansion....
What is volume expansion?
Volume expansion is the increase in the volume of a substance due to an increase in temperature. This is caused by the particles in the substance gaining kinetic energy and moving further apart, resulting in an increase in the space they occupy.
What is the coefficient of volume expansion?
The coefficient of volume expansion is a measure of how much a substance's volume will increase per degree of temperature change. It is denoted by the symbol β and is usually given in units of per degree Celsius (°C).
How is volume expansion calculated?
The change in volume (ΔV) of a substance due to a change in temperature (ΔT) can be calculated using the formula ΔV = V₀βΔT, where V₀ is the initial volume and β is the coefficient of volume expansion. This formula assumes that the expansion is uniform.
What factors can affect volume expansion?
The coefficient of volume expansion and the resulting expansion in volume can be affected by factors such as the type of substance, the temperature change, and the pressure. Substances with higher coefficients of expansion will experience a greater increase in volume for the same change in temperature.
What are some practical applications of volume expansion?
Volume expansion is an important concept in many fields, including thermodynamics, engineering, and materials science. It is used in the design of structures and materials that can withstand temperature changes without breaking or deforming. It is also used in the design of thermometers and other temperature measuring devices.
12K
20K
