Finding Integer with Chinese Remainder Theorem
The discussion centers on finding an integer between 1 and 1200 that satisfies specific modular conditions using the Chinese Remainder Theorem. The initial conditions were incorrectly stated as x ≡ 1 (mod 9), x ≡ 10 (mod 11), and x ≡ 0 (mod 13), but it should have been x ≡ 1 (mod 9), x ≡ 2 (mod 11), and x ≡ 6 (mod 13). The calculations using the theorem led to the conclusion that the integer is 838, which checks out. The participants agree that the correct remainders are indeed (1, 2, 6). This clarification ensures the accuracy of the solution process.
Math100
A certain integer between ## 1 ## and ## 1200 ## leaves the remainders ## 1, 2, 6 ## when divided by ## 9, 11, 13 ##, respectively. What is the integer?
None.
Consider a certain integer between ## 1 ## and ## 1200 ##.
Then ## x\equiv 1\pmod {9}, x\equiv 10\pmod {11} ## and ## x\equiv 0\pmod {13} ##.
Applying the Chinese Remainder Theorem produces:
## n=9\cdot 11\cdot 13=1287 ##.
This means ## N_{1}=\frac{1287}{9}=143, N_{2}=\frac{1287}{11}=117 ## and ## N_{3}=\frac{1287}{13}=99 ##.
Observe that
\begin{align*}
&143x_{1}\equiv 1\pmod {9}\implies 8x_{1}\equiv 1\pmod {9}\implies x_{1}\equiv 8\pmod {9},\\
&117x_{2}\equiv 1\pmod {11}\implies -4x_{2}\equiv 1\pmod {11}\\
&\implies -12x_{2}\equiv 3\pmod {11}\implies -x_{2}\equiv 3\pmod {11}\implies x_{2}\equiv 8\pmod {11},\\
&99x_{3}\equiv 1\pmod {13}\implies -5x_{3}\equiv 1\pmod {13}\\
&-15x_{3}\equiv 3\pmod {13}\implies -2x_{3}\equiv 3\pmod {13}\\
&-12x_{3}\equiv 18\pmod {13}\implies x_{3}\equiv 5\pmod {13}.\\
\end{align*}
Now we have ## x_{1}=8, x_{2}=8 ## and ## x_{3}=5 ##.
Thus ## x\equiv (1\cdot 143\cdot 8+2\cdot 117\cdot 8+6\cdot 99\cdot 5)\pmod {1287}\equiv 5986\pmod {1287}\equiv 838\pmod {1287} ##.
Therefore, the integer is ## 838 ##.
Everything is fine until ...
Math100 said:
Homework Statement:: A certain integer between ## 1 ## and ## 1200 ## leaves the remainders ## 1, 2, 6 ## when divided by ## 9, 11, 13 ##, respectively. What is the integer?
Relevant Equations:: None.
... which I did not understand. Shouldn't it be ##(1,2,6)## instead of ##(1,10,0)?## Especially, because ...
Observe that
\begin{align*}
\end{align*}
... everything after that is correct again.
fresh_42 said:
Everything is fine until ...... which I did not understand. Shouldn't it be ##(1,2,6)## instead of ##(1,10,0)?## Especially, because ...
Yes, I was wrong. It should definitely be (1, 2, 6).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
