Finding Position at a Specific Time Using Kinematic Equations
  • Thread starter Thread starter onetroubledguy
    Acceleration Time
The discussion focuses on calculating the position of a particle at t=5s using kinematic equations. The particle starts from rest at 0m with an initial velocity of 0m/s, and the user attempts to find the position by breaking the problem into two segments due to changing acceleration. Initial calculations for the first segment yield 4.5m at t=3s, and subsequent calculations suggest adding this to the next segment's result, leading to confusion. The key correction is that the position from the first segment should not be added again, as it is already accounted for in the second segment's calculations.
onetroubledguy
Ok here's the graph:
http://img268.imageshack.us/img268/8762/acvt9nz.jpg
We are given that the particle starts from rest at the initial position 0m with the initial velocity 0m/s. I need to find what the position of the particle is at t=5s.
Since acceleration is changing here, I didn't know what to do so I broke the problem up. First, I wanted to find the position at t=3s. I used the equation
x = x0 + v0t + 1/2at^2 where x0 = 0m, v0 = 0m/s, a = 1m/s^2, and t = 3s.
I came up with 4.5m.
Next, I did the same thing for the lower part; I used the same equation but with x0 = 4.5m, v0 = 3m/s, a = -2m/s^2, and t = 2s. I came up with 6.5m and added it to first distance (4.5m) to get 11m.
Obviously this is wrong. Any help you can provide would be much appreciated. Thank you.
wouldn't it be just the answer to your second part? you're starting at the point where the first part left off. you don't need to add that onto your answer as you've already accouned for the position up to 3 seconds with the x_0 in your second kinematic eqation.
your individual calculations are correct. However, you have to be careful of the SIGN of the acceleration in each part. What is the acceleration (as read fro mteh graph) for the first 3 seconds and then the final 2 seconds?
You're right. I always do stupid things like that! Grr...thanks.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
