Finding position from velocity
In summary, the conversation is discussing finding the position of a body at a given time based on its velocity and initial position. The solution involves finding the constant term and then using it to solve for the body's position using the given equation. There appears to be a typo in the solution manual, as the correct answer is 16t^2 - 2t + 1.
bobsmith76
336
Give the velocity v = ds/dt and initial position of a body moving along a coordinate line.
Find the body's position at time t.
v = 32t - 2, s(.5) = 4
Here's how the solution manual does it:
step 1. v = ds/dt = 32T - 2
step 2. s = 16T^2 - 2T + C; at s = 4 and T = .5 (I understand this)
step 3. (find C)
C = 1 (I understand how to do that)
step 4. therefore
s = 6T^2 - 2T + 1
Why 6T^2? How did they get that. I don't understand.
bobsmith76 said:
step 4. therefore
s = 6T^2 - 2T + 1
That looks like a typo on their part. The answer is 16t^2 - 2t + 1, as you originally got.
FAQ: Finding position from velocity
1. How do you find position from velocity?
To find position from velocity, you can use the formula: position = initial position + (velocity x time). This formula takes into account the initial position and the change in position over a specific amount of time.
2. What is the relationship between velocity and position?
Velocity is the rate of change of an object's position over time. In other words, velocity tells us how fast an object is moving and in what direction. The position of an object is its location in space at a specific time. So, velocity and position are closely related as they both describe the movement of an object.
3. Can you find position from a velocity-time graph?
Yes, you can find position from a velocity-time graph. The position of an object at a specific time can be determined by finding the area under the velocity-time graph for that time interval. This is because the area under the graph represents the change in position over that time interval.
4. How does acceleration affect finding position from velocity?
Acceleration is the rate of change of velocity over time. So, if an object is accelerating, its velocity is changing, which means its position is also changing. In this case, the formula for finding position from velocity becomes: position = initial position + (initial velocity x time) + (1/2 x acceleration x time^2).
5. Can you find position from velocity if the velocity is changing?
Yes, you can still find position from velocity if the velocity is changing. This is because the formula for finding position from velocity takes into account the initial position and the change in position over time, regardless of whether the velocity is constant or changing. However, if the velocity is changing, you may need to use the more complex formula that takes into account acceleration (as mentioned in the previous answer).
