Chemistry Finding rate constant from pressure change in an experiment
To find the rate constant (k) from pressure changes in an experiment involving hydrogen peroxide and a catalyst, the initial concentration of hydrogen peroxide is 0.88 mol/dm^3, and pressure changes were measured using a Vernier Gas Pressure Sensor. The maximum pressure recorded was 145 kPa at 70°C, and the concentration of oxygen produced after 180 seconds was calculated to be 0.477 mol/dm^3. The rate of hydrogen peroxide depletion was determined to be 0.0053 mol/dm^3/s, leading to a negative final concentration, indicating a potential error in the calculations. The user plans to use the equation k = rate / [final concentration hydrogen peroxide] to find k, but acknowledges that the reaction may not have gone to completion. Further assistance is sought to resolve these issues and accurately plot an Arrhenius graph for activation energy.
HoneyBee
I measured the change in pressure for the decomposition of hydrogen peroxide in the presence of a manganese(IV) oxide catalyst at 5 different temperatures
MnO2(s)
2H2O2(l) --> O2(g)+2H2O(l)
Is there any way that I can find concentrations and then find the rate constant, k? And, using them, make an Arrhenius graph to find activation energy (including the catalyst)? Any help would be much appreciated.
Change in pressure was found using a Vernier Gas Pressure Sensor. The starting concentration of hydrogen peroxide was 3% or 0.88mol. The starting pressure was always around 98kPa. The catalyst and hydrogen peroxide were mixed together after the stopper was put on the flask. The increasing pressure was measured and the highest it went to (at 70C) was around 145kPa.
Here is an example of what I have done so far to try and find the rate constant to plot on an Arrhenius graph:
At 303.15K
PV=nRT
P/(RT)=n/v, which is the same as concentration.
120.3/(8.314*303.15) = 0.477 mol/dm^3
0.477mol/dm^3 is the final concentration of oxygen created after 180s had elapsed.
0.477mol/dm^3/180s = 0.00265 mol/dm^3/s
The ratio between oxygen and hydrogen peroxide is 1:2, therefore the rate at which hydrogen peroxide was depleted at is 0.0053 mol/dm^3/s
The ending concentration must be 0.88M - (0.0053mol/dm^3/s x 180s) = -0.074 mol/dm^3
And this is where I think something has gone wrong... The pressure continued to increase even after this 180s so I do not think the reaction went to completion.
I would then use the equation k = rate / [final concentration hydrogen peroxide] to find k.
See my answer on chemical forums.
Haha I guess you can tell I really wanted some help. Anyways thank you again!
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
