Finding Shear Stress at Point E on a Beam
To determine the shear stress at point E on the beam, the formula τE = V*Q/I*t is used, where V is the shear force. The challenge lies in calculating Q for point E, particularly in identifying its location relative to the neutral axis. Point E is suggested to be at a distance of 0.80*b from the top edge of the upper flange, which helps in calculating shear stress. There is a clarification that shear stress should be evaluated at a section rather than at a single point. Understanding the geometry and assumptions about point E's location is crucial for accurate calculations.
aaronfue
Determine the shear stress, \tauE, at point E that corresponds to the maximum shear force along the length of the beam. V = 25kN
b= 55 mm
c=150 mm
d=110 mm
e=65 mm
\tauE = \frac{V*Q}{I*t}
Q = \bar{y}'*A'
I was able to find the shear stress for point D, but I'm having trouble finding point E. How do I find Q for that point? I read an example in my textbook but there was not much of an explanation.
Is point E the centroid for the area when the neutral axis is at point D? If this is the case, I would be able to find the shear stress.
Unfortunately, the diagram is not clear on where point E is located. The shear stress in the beam takes a large jump at the intersection of the upper flange and the web of the beam. In any case, Q will be the first moment of the area between E and the top of the flange, referenced about the neutral axis.
I am not sure, since I did not try it.
Technically speaking, we could say point E is located at a distance 0.80*b from the top edge of the upper flange. I.e., point E is located at (0.50*c + 0.20*b) from point D. Therefore, based on this assumption, you could find the shear stress at point E.
Thanks for all of the input. I was told to assume that point E was located at the point where the web meets the flange. Great drawing!(sarcasm) Got this one wrong.
Glad you are sorted now. However, shear stress is not evaluated at a point, but at a section. There is a difference.
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
