Finding Subspaces that Satisfy Specific Intersections in \mathbb{R}^3
  • Thread starter Thread starter moonbeam
    Subspaces
moonbeam
Find subspaces A, B, and C of \mathbb{R}^3 so that A \cap B \cap C \ne \{\vec{0}\} and (A + B) \cap C \ne A \cap C + B \cap C.
You can specify a subspace by the form A = span\{\vec{e}_1, \vec{e}_2\}.
A + B is the set of all vectors in \mathbb{R}^3 of the form \vec{a} + \vec{b}, where \vec{a} is in A and \vec{b} is in B.
I’ve been trying to guess. I’ve tried A as a line, B as a plane containing A, and C as \mathbb{R}^3 itself. I’ve tried making all three subspaces planes that intersect in a line. I’ve tried making A and B planes that intersect in a line and C as \mathbb{R}^3 itself. I’ve tried making A equal to B and C another plane intersecting them in a line.
Finding A \cap B \cap C \ne \{\vec{0}\} is not my problem. I’m having trouble satisfying the second specification: (A + B) \cap C \ne A \cap C + B \cap C.
if A and B are subspaces then so is A+B. Can you find a basis of A+B knowing a basis of A and B? How does this help?
We also know that the intersection of subspaces is a subspace.
I can't find the bases without knowing how many dimensions each subspace is. How do I even know what dimension to make the subspaces A, B, and C?
Check my awkward method below,
Imagine stuff like Cartesian coordinate systems, then we have X, Y,Z axis(orthongol to each other).The R^3 can be expressed by points in OXYZ, with XZ plane at the bottom.
XY plane and bottom make a line x. YZ plane and bottom make a line z.[WHY I CANNOT COPY YOUR EQUATIONS AND JUST PASTE THEM HERE?]
According to definition of XY+YZ, the set has another POINT OTHER THAN x line and z line , but that point, e.g. point (1,0,1)=(1,0,0)+(0,0,1) ,lie on the bottom plane.
Or using set language
A={(x,y,z);x=0}, B={(x,y,z);z=0}, C={(x,y,x);y=0}
A and C make {(x,y,z);x=0,y=0}, B and C make {(x,y,z);z=0,y=0};
(A+B) and C includes a point {(1,0,1)},This compltes your problem.
In this situation the subspaces A, B, and C do not satisfy the first requirement: A \cap B \cap C \neq \{\vec{0}\}. The only vector in common among the 3 planes is the zero vector. But the problem is asking for subspaces A, B, and C, that intersect in more than just the case of the zero vector.
moonbeam,
I had thought your questions are separate (since you said meeting the first one is not your problem).
But it is handy as well. Shift the bottom to one unit.See below
A={(x,y,z);x=0}, B={(x,y,z);z=0}, C={(x,y,z);y=1}
A and C make {(x,y,z);x=0,y=1}, B and C make {(x,y,z);z=0,y=1};
(A+B) and C includes a point (1,1,1),This compltes your problem
uiulic said:
moonbeam,
(A+B) and C includes a point {(1,1,1)},This compltes your problem
The point (1, 1, 1) is not the same as the vector <1, 1, 1>. If the planes only meet at one particular point, then their intersection is just the zero vector. So the intersection of these 3 planes is still just the zero vector. I need the 3 planes to intersect in a line segment, not just one point.
Where is your statement from? I haven't touched mathematics for many years, but I believe your understanding is completely wrong.
A AND B AND C={(0,1,0)} , IS THIS A ZERO VECTOR IN R^3? You may be confused by the point(working as a vector) with the vector with magnitude and direction stuff? That can be called a located vector (by serge lang), which can be taken as an ordered pair of points.In vector space (subspace), points (if you think of it as an element in your R^3) ARE vectors. Also, don't get confused by the vector used in tensor analysis. Vector space is a set. It is easier to use some set language to help your analysis. But vector space can be an element in another set. What really is an element, or a set, or a vector space in your analysis of the problem, is your decision depending on what kind of problems ;and once you decide (e.g. a point is a vector), then the analysis must be consistent. Since all your statements are sets in R^3, then A,B,C ARE SETS including many elements (each element belongs to R^3, and each element can be expressed by an ordered triple or a point with the three coordinates). That's why I write them as written.Noting I embedded a coordinate system to help our analysis. Under such a coordinate system, the problem can be easily described. Now, I only need to find one case that DISobey the corresponding assertion.
(make sure you know what A+B is about according to its definition, also make sure THE ELEMENTS IN A+B IS STILL POINTS OR an ordered triple WITH THREE COORDINATES )
(A+B) and C includes a point (1,1,1), (this is just an alternative to equation problem, but this can be obtained without resorting to equations, only need to make a big guess as your case is simple). This point will be neither in {(x,y,z);x=0,y=1} nor in {(x,y,z);z=0,y=1} (this is obvious). This compltes your problem
This is what I eventually came up with and I got confirmation from a member of another math forum.
Let A = span\{\left[\begin{array}{c}1\\0\\0\end{array}\right] \left[\begin{array}{c}0\\0\\1\end{array}\right]\}.
Let B = span\{\left[\begin{array}{c}0\\1\\0\end{array}\right] \left[\begin{array}{c}0\\0\\1\end{array}\right]\}.
Let C = span\{\left[\begin{array}{c}1\\1\\0\end{array}\right] \left[\begin{array}{c}0\\0\\1\end{array}\right]\}.
Then A \cap B \cap C = span\{\left[\begin{array}{c}0\\0\\1\end{array}\right]\},
(A+B) \cap C = span\{\left[\begin{array}{c}1\\1\\0\end{array}\right] \left[\begin{array}{c}0\\0\\1\end{array}\right]\},
and A \cap C + B \cap C = span\{\left[\begin{array}{c}0\\0\\1\end{array}\right]\}.
\therefore (A + B) \cap C \ne A \cap C + B \cap C.
