Finding tension and force in a cord
  • Thread starter Thread starter lesdavies123
    Force Tension
lesdavies123
Hey there,
Here is the problem: A weight of 2 kg is suspended by a single cord. An horizontal force keeps the cord at 37 degrees from the vertical. Find (a) the force, (b) the tension in the cord.
Relevent equations are Weight = mass x acceleration, I use 9,81 m/seconds squared for the gravitational acceleration.
Here is my attempt at a solution:
I started by drawing a diagram of the problem. Then I tried to set my equations:
The sum of my forces in x = 0 N = -cos(90-37)T
First of all I am unsure of this one, this doesn't really make sense because my weight isn't moving horizontally, while if I base myself on this equation it should be in movement.
The sum of my forces in y = 0 N= -Weight + sin(90-37)T
Basically this is what I thought but I soon realized that these two equations could not work, maybe the second one but the first one definitely not. Then, I couldn't figure out what I was missing. Can you guys help me out, and show me the methodology to do this problem.
Thanks a lot everybody!
Solve for T from the sum of forces in Y equation, since the only unknown is T.
Now substitute T into the "x Sum" equation to solve for the horizontal force.
The x direction equation should be:
0 = Fh - Tsin 37
That equation does not imply movement, it is that the horizontal component of the rope tension is balanced by the restraining force, Fh
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
