MHB Finding the Area of Shaded Part
  • Thread starter Thread starter karush
    Area
The discussion focuses on calculating the area of a shaded region involving triangles and a sector of a circle. The area of triangle OAPB is derived from the areas of similar triangles OAP and OBP, resulting in a total of 110.4 cm². The area of the sector is calculated as 94.2 cm², leading to a shaded area of 16.2 cm² after subtraction. An alternative method for finding the shaded area is also presented, yielding approximately 15.33 cm². The calculations have been verified through multiple approaches, confirming their accuracy.
karush
MHB
find the area of the shaded part
first I tried to find out the area of $OAPB$ which can be found by adding triangles $OAP$ and $OBP$ which are similar, $AP$ and $BP$ are perpendicular to the radius and tangent to the circle$BP = 12\tan{37.5^0}=9.2 cm^2$
area $\Delta OBP= \frac{1}{2}(12)(9.2)=52.2 cm^2$
area $OAPD = 2(52.2)= 110.4 cm^2$
area of sector $\frac{75}{360}\pi 12^2 = 94.2 cm^2$
so shaded area $= 110.4 - 92.2 = 16.2 cm^2$
just seeing if this is OK i went over it quite a few times...
no ans given ...(Cool)(Coffee)
Mathematics news on Phys.org
Area of $\displaystyle OAPB$ is:
$\displaystyle 15\cdot12\sin(37.5^{\circ})$
Subtract the area of sector $\displaystyle OAB$:
$\displaystyle A_S=15\cdot12\sin(37.5^{\circ})-\frac{1}{2}12^2\cdot\frac{5\pi}{12}=180\sin(37.5^{\circ})-30\pi\approx15.329277613875924$
I have verified this using another method as well.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
