Finding the Coefficient of Friction?
To find the coefficient of friction for a sled being pulled at a constant velocity, the horizontal force exerted by the boy is calculated as 5N using the cosine of the angle. Since the sled moves at constant velocity, the frictional force equals the applied force, leading to the equation 5N = mew (5kg x 9.8). The calculated coefficient of friction was found to be 0.102, but the correct answer is 0.12. The discussion also raises questions about the gravitational force acting on the sled and the normal force before and after the boy pulls it. Understanding these forces is crucial for accurately determining the coefficient of friction.
Brodo17
A boy pulls a sled of mass 5kg with a rope that makes an angle of 60 degrees w/ respect to the horizonal surface of the frozen pond. The boy pulls on the rope with a force of 10N and the sled moves with constant velocity. What is the coefficient of friction between the sled and the ice?
F=ma
f=mewFN
First I found the horizonatal force that the boy is exerting on the sled:
Cos60 X 10 = 5N
Then I thought that since the acceleration is constant that the sum of the forces must be zero. This would mean that the frictional force must be equal to the applied force of 5N
So, I said 5N = mew (5kg X 9.8)
And I found mew to be .102
However apparently the answer is .12
Thanks!
What is the force of gravity acting on the sled?
What is the normal force before the boy pulls on the sled? What about after?
I hope these help.
Both forces in the x and y direction must sum to 0, since its in constant velocity.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
