Finding the Constant a for a Given Point on a Linear Equation
In summary, the value of the constant a that makes the graph of the given equation pass through the given point is 19. This can be verified by substituting the values of x and y into the equation and confirming that it satisfies the equation.
mathdad
1,283
You are given an equation and a point. In each case, find the value of the constant a so that the graph of the equation passes through the given point.
y = -5x - a; (-4, 1)
Solution:
Let x = -4 and y = 1
y = -5x - a
1 = -5(-4) - a
1 = 20 - a
1 - 20 = - a
-19 = -a
-19/-1 = a
19 = a
Correct?
Mathematics news on Phys.org
Solution:
y = -5x - a
1 = -5(-4) - a
1 = 20 - a
1 - 20 = - a
-19 = -a
-19/-1 = a
19 = a
Correct?
The answer is right. to check the correctness of the result you can put the value and check
$y= -5x - 19$ and at $x = -4 $ we get $y= - 5 * (-4) -19 = 20-19 =1$ which is true
Very interesting. I will do likewise for the other question.
FAQ: Finding the Constant a for a Given Point on a Linear Equation
What is the purpose of finding the value of constant a?
The value of constant a is an important factor in many scientific equations and models. It represents a fixed quantity that remains unchanged throughout the experiment or study. Finding the value of a allows for accurate calculations and predictions.
How do you find the value of constant a?
The method for finding the value of constant a can vary depending on the specific equation or model being used. In general, it involves collecting data from experiments or observations and using mathematical techniques such as regression analysis to determine the most accurate value for a.
Why is it important to determine the correct value of constant a?
The value of constant a can significantly impact the results and conclusions of scientific studies and experiments. If the value of a is incorrect, it can lead to inaccurate predictions and potentially render the entire study or experiment invalid.
Are there any common techniques for finding the value of constant a?
Yes, there are several common techniques for finding the value of constant a, including linear regression, least squares regression, and curve fitting. These techniques involve analyzing data and determining the best fit for a line or curve that represents the relationship between variables in an equation.
Can the value of constant a change over time?
In most cases, the value of constant a is assumed to remain constant throughout an experiment or study. However, in some cases, the value of a may change over time. This is usually accounted for by incorporating additional variables or factors into the equation or model.
