Finding the Coordinates of Point A in a Force Equilibrium System
  • Thread starter Thread starter Nivlac2425
    Equilibrium Force
The problem involves finding the coordinates of point A in a force equilibrium system, where the sum of forces in both the x and y directions equals zero. The system includes a downward weight W and two equal tensions T in the ropes. Key considerations include the distance ε between the weight and its pulley, and the angles α and β of the ropes with the horizontal. By resolving the tensions into components, it is determined that the angles are equal (α = β = 30°), leading to the equations for x and y coordinates based on trigonometric relationships. This approach effectively addresses the equilibrium conditions to solve for point A's coordinates.
Nivlac2425
The system is in equilibrium. What are the coordinates of point A?
(see attached image)
ƩF_y = 0
ƩF_x = 0
The sum of forces in the x and y directions is zero since the system is in equilibrium. At point A, I also know that there is a weight W directed downwards, and each of the two tensions in the ropes T are equal in magnitude.
I was told that this "proof" problem required consideration of the distance between the weight on the left and its pulley (call it ε), and also the two angles (α and β) between each of the two ropes at point A with the horizontal.
Although I was given these hints, I still can't figure out where to start in the problem. Can anyone help me out here? Thanks!
Actually all the tension of the strings are equal.
Using these values, you can find the angles by resolving the components.
ƩF_y = 0
ƩF_x = 0
What is the tension in each of the three ropes ?
I believe the tensions are equal and they are all equal to W
Correct.
What does that tell you about the angles made by the three ropes at point A ?
SammyS said:
Correct.
So if I resolve the tensions into their components, and realize that the sum of forces in x and y are both equal to zero, I get the following relations:
sin(α) + sin(β) = 1
cos(α)=cos(β)
This tells me that the angles must be equal, and that α = β = 30°
And since: tan(α) = (h+y)/(b-x) and tan(β) = y/x,
I get x = (1/2)[b - hcot(30°)] and y = (1/2)[btan(30°) - h]
Is this the correct way to think about the problem?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
