Finding the current in a solenoid
The discussion revolves around calculating the maximum current (Io) in a solenoid and its effect on a surrounding coil. The solenoid has specific parameters, including a frequency of 60 Hz and a defined resistance. The calculations involve determining the magnetic flux through the coil and applying Faraday's law to find the induced current. There is confusion regarding the use of radians in calculations, particularly in determining the time when the sine function reaches its maximum. The final calculations lead to an undefined result due to the cosine function equating to zero, indicating a need for clarification in the approach.
kamhogo
A 40-turn, 4.0-cm-diameter coil with R = 0.40Ω surrounds a 3.0-cm-diameter solenoid. The solenoid is 20 cm long and has 200 turns. The 60 Hz current through the solenoid is I = Io sin (2Πft). What is Io if the maximum current in the coil is 0.20A?
Ncoil = Nc= 40 turns
Acoil = Ac = 4π*(10^-2) m^2
Rcoil = 0.40Ω
n = Nsol/Lsol = 200 turns / 0.2 m = 1000/m
Bsol = μo*n*Isol
Isol = Io sin (120Πt)
Asol = 2.25π*(10^-4) m^2
φm = Nc*Bsol*Asol (Magnetic flux through coil)
∈coil = φm/dt
Icoil = Nc*∈coil/Rcoil
Isol is max when Io sin (2Πft) = Io, i.e. when sin 120Πt = 1, i.e. when t ≈ 0.2387s
From Isol to Bsol
Bsol = 1000*μo*(Io sin (120Πt)
From Bsol to Flux through coil (φm)
φm = 40*(1000*μo*(Io sin (120Πt))*(2.25π*(10^-4) m^2) = 9*(Io sin (120Πt)
From φm to ∈coil
∈coil = (9*(Io sin (120Πt))/dt= 9*Io*120Π* cos (120Πt) = 3392.92*Io*cos (120Πt)
From ∈coil to Icoil
Icoil = (40*3392.92*Io*cos (120Πt))/0.40Ω = 339292.0066 *Io*cos (120Πt) = 0.20 A
5.8946*(10^-7) = Io*cos (120Πt); t ≈ 0.2387 s ⇒ Io = 140.45A
Is this correct?
Rcoil = 0.40Ω
Bsol = μo*n*Isol
∈coil = φm/dt
That step is incorrect. You have to work in radians.
So 120*pi*t = 1.570796327
t = 0.004167 s ...??
And why in radians?
kamhogo said:
So 120*pi*t = 0.5*pi
t = (1/240) s ...??
And why in radians?
But then in the last step I get :
(5.8946*10^(-7)) / cos (0.5*pi) = infinity...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
