Finding the current in each resistor - Kirchhoff
To find the current in each resistor using Kirchhoff's Current Law (KCL), start by labeling each current in the circuit with an arbitrary direction. This consistent labeling will help in setting up the equations needed to solve for the currents. If a calculated current value is negative, it indicates that the actual direction is opposite to the assumed direction. The approach involves analyzing the circuit's loops and junctions systematically. Understanding this method is crucial for successfully applying KCL in circuit analysis.
radator
Find the current in each resistor of this circuit.
Kirchoff's Current Law
I just need a nudge in the right direction. I am fairly sure Kirchoff's Current Law comes into play, and have counted 6 loops and 4 junctions. I am not sure where to proceed next; the problems we've done before with KCL usually gave us currents and their directions. Any help on getting started would be appreciated.
Thank you.
That should be the right approach -- a lot of equations, but it will all work out in the end. The strategy for the direction of the current is just to label each different current in the diagram with an arbitrary direction, as long as that direction is consistent every time you use it. So, for example, you would just say that the current across R6 points up (or down, if you want). It really doesn't matter. You'll find out in the end when you solve for the value of the current -- if the value is negative, that just means the current goes in the opposite direction of the arrow, and you happened to guess wrong, but it still conveys the same meaning.
Thank you so much! That's the part I was missing: using arbitrary directions. I get it now.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
