MHB Finding the domain of this function.
  • Thread starter Thread starter cbarker1
    Domain Function
The function f(x) = 1/√(x² - 2x cos(θ) + 4) has a domain that varies based on the value of θ within [0, π]. For θ = π/2, x can take any real value, while for θ = 0 and θ = π, x cannot equal 2 and -2, respectively. For values of θ between 0 and π, the expression under the square root is always positive, indicating that the domain is all real numbers. The discussion highlights the importance of understanding the behavior of the quadratic expression in relation to θ. Ultimately, the domain of the function is confirmed to be all real numbers, R.
cbarker1
MHB
Dear Everyone,
I am having some trouble find the domain with this function: $f(x)=\frac{1}{\sqrt{x^2-2x\cos(\theta)+4}}$ and $\theta\in[0,\pi]$.
My attempt:
I know that the denominator needs to be greater than 0. So $\sqrt{x^2-2x\cos(\theta)+2}>0$. I squared both side of the inequality. Then I use the quadratic formula in terms of x: $x>\frac{2\cos(\theta)\pm\sqrt{4(\cos(\theta)^2-4}}{2}$. With some simplification and using the trig. identities, I got $x> \cos(\theta)\pm \sin(\theta)$. But I do not know how to proceed from here. Thanks,
Cbarker1
Mathematics news on Phys.org
the domain depends of the value of $\theta$ ...
$\theta = \dfrac{\pi}{2} \implies f(x) = \dfrac{1}{\sqrt{x^2+4}}$
... $x$ can be any real value
$\theta = 0 \implies f(x) = \dfrac{1}{\sqrt{(x-2)^2}} = \dfrac{1}{|x-2|}$
... $x \ne 2$
$\theta = \pi \implies f(x) = \dfrac{1}{\sqrt{(x+2)^2}} = \dfrac{1}{|x+2|}$
... $x \ne -2$
for $0 < \theta < \dfrac{\pi}{2}$
$0 < \cos{\theta} < 1 \implies 0 < 2x\cos{\theta} < 2x$ for $x > 0 \implies x^2-2x\cos{\theta}+4 > x^2 - 2x + 4 \ge 0$
$0 < \cos{\theta} < 1 \implies 2x < 2x\cos{\theta} < 0$ for $x < 0 \implies x^2-2x\cos{\theta}+4 > 0$
for $\dfrac{\pi}{2}< \theta < \pi$
$-1 < \cos{\theta} < 0 \implies -2x < 2x\cos{\theta} < 0$ for $x > 0 \implies x^2-2x\cos{\theta}+4 > 0$
$-1 < \cos{\theta} < 0 \implies 0 < 2x\cos{\theta} < -2x$ for $x < 0 \implies x^2-2x\cos{\theta}+4 > x^2-2x+4 \ge 0$
Cbarker1 said:
Dear Everyone,
My attempt:
I know that the denominator needs to be greater than 0. So $\sqrt{x^2-2x\cos(\theta)+2}>0$. I squared both side of the inequality. Then I use the quadratic formula in terms of x: $x>\frac{2\cos(\theta)\pm\sqrt{4(\cos(\theta)^2-4}}{2}$. With some simplification and using the trig. identities, I got $x> \cos(\theta)\pm \sin(\theta)$. But I do not know how to proceed from here.Thanks,
Cbarker1
$\displaystyle \begin{align*} x^2 - 2\cos{ \left( \theta \right) } \, x + 4 &> 0 \\ x^2 - 2\cos{ \left( \theta \right) }\, x + \left[ -\cos{ \left( \theta \right) } \right] ^2 - \left[ -\cos{ \left( \theta \right) } \right] ^2 + 4 &> 0 \\
\left[ x - \cos{ \left( \theta \right) } \right] ^2 - \cos^2{ \left( \theta \right) } + 4 &> 0 \end{align*}$
Note that $\displaystyle \left[ x - \cos{ \left( \theta \right) } \right] ^2 \geq 0 $ for all $x, \theta$ and also
$\displaystyle \begin{align*} 0 \leq \cos^2{ \left( \theta \right) } &\leq 1 \textrm{ for all } \theta, \textrm{ so } \\ -1 \leq -\cos^2{ \left( \theta \right) } &\leq 0 \\ 3 \leq -\cos^2{ \left( \theta \right) } + 4 &\leq 4 \end{align*} $
so that means $\displaystyle \left[ x - \cos{ \left( \theta \right) } \right] ^2 - \cos^2{ \left( \theta \right) } + 4 \geq 3 $ for all $x, \theta $.
Since the square root amount is never any less than 3, it's going to always be defined. The domain is $\mathbf{R}$.
that is correct ... I was looking at $x^2 \pm 2x +4$ as if it were $x^2 \pm 4x +4$ when I factored.
mea culpa.
mea culpa.
Sorry Skeeter, didn't mean to upset you. I just liked my strategy so wanted to share it hahaha.
No upset ... it happens.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
