Finding the Equation of a Line
  • Thread starter Thread starter fogvajarash
    Line
To find the scalar equations of a line passing through point P(6, 0, 3) and intersecting another line while being perpendicular to it, one must first determine the intersection point by solving for the parameter t0. The direction vector of the desired line can be derived from the intersection point and the original point P. It is clarified that direction vectors do not need to be expressed in their simplest integer form, as they can be scaled. The solution involves finding a second point on the line using the perpendicular relationship and then constructing the line's equation from the two points. This approach effectively leads to the final equation of the line.
fogvajarash
Find the scalar equations of the line passing through p(6, 0, 3), intersecting the line (x y z) = (1 2 -3) + t(1 -2 0) and perpendicular to it
I don't know where to start with the problem, I tried using projections and then giving out equations for the scalar product of the two lines (which is 0) and the equations of the points of intersection, but there are so many variables I can't do anything with them. I'm stuck with this problem.
If t0 is the value of t where they intersect then (6,0,3)-[(1,2,-3)+t0(1,-2,0)] must be perpendicular to (1,-2,0), yes? Find t0. There aren't that many variables. There's really only one.
Got it, I can't believe i was so blind. Just asking, does the direction vector of a line always have to be given in the lowest integers as possible? (for example, we can have a direction vector (8 -4 2) and can we express it as (4 -2 1)?
If the two direction vectors point in the same direction then it's the same line. No, there's no requirement to do it like that. You could equally well say (400, -200, 100) or (.4, -.2, .1).
A solution to the problem.
in order to find an equation of a line you need two things: a direction (V) and a point (Po). In order to find the direction we need to find another point on the wanted line. To do this, we use the perpendicular line to our advantage. I set x=6 since Z always = -3 then I found the parameter t and plugged in the value to get the y... Now you have a second point on the wanted line (P1) the direction vector can now be found (vector from Po to P1) then by taking this vector and one to those 2 points (doesn't matter, Po or P1) we can put into vector form r=<ro>+t<v> and then put it into parametric from... Walah! you're done. :)
The working out suggests first equating ## \sqrt{i} = x + iy ## and suggests that squaring and equating real and imaginary parts of both sides results in ## \sqrt{i} = \pm (1+i)/ \sqrt{2} ## Squaring both sides results in: $$ i = (x + iy)^2 $$ $$ i = x^2 + 2ixy -y^2 $$ equating real parts gives $$ x^2 - y^2 = 0 $$ $$ (x+y)(x-y) = 0 $$ $$ x = \pm y $$ equating imaginary parts gives: $$ i = 2ixy $$ $$ 2xy = 1 $$ I'm not really sure how to proceed from here.
