Finding the Equilibrium Position for Three Charges
To find the equilibrium position for the third charge, the net electrostatic force on it must be zero, which occurs when the forces from the other two charges balance. The initial setup involves two positive charges, with the third charge needing to be positioned between them. The user attempted to set up the equation using Coulomb's law but encountered difficulties with cross-multiplication and solving for the distance. Clarification was provided that a quadratic equation should be formed after correctly cross-multiplying both sides. The discussion emphasizes the need to accurately manipulate the equation to find the correct position for the third charge.
Fireupchip
A charge of 2.21E-9 C is placed at the origin, and a charge of 3.78E-9 C is placed at x = 1.60 m. Find the position at which a third charge of 2.94E-9 C can be placed so that the net electrostatic force on it is zero.
Coloumb's law
All 3 charges are positive, so for the net force to be zero, I believe that the 3rd charge will go in the middle of the other 2 charges.
+q1 |----1.60m - r -----| +q3 |------ r------| +q2
Knowns:
q1 = 2.21 x 10^-9 C
q2 = 3.78 x 10^-9 C
q3 = 2.94 x 10^-9 C
r (between q1 and q2) = 1.60 m
F1 = F2
the k and q3 both cancel, leaving me with:
q1 / (1.60m - r)^2 = q2 / r^2
I cross multiplied, giving me:
q1 / q2 = (1.60m - r)^2 / r^2
This is where I think I'm having a problem. From this point, I found 2 different answers, and both turned out to be wrong: 0.91m and 1.05m (both from q1). Can anyone please help?
You didn't completely "cross multiply" (and I dislike that term). You did multiply on both sides by the denominator on the left, (160- r)^2. Now multiply on both sides by the denominator on the right to get (q1/q2)r^2= (160- r)^2. Multiply out the square on the right and you a quadratic equation to solve for r.
So if I multiply the square out on the right, there'll still be an r on the left side.
My physics professor said to avoid using the quadratic equation in this situation. Where am I going wrong?
Anyone?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
