Finding the Equilibrium Separation in a Diatomic Molecule: A Scientific Approach
The discussion focuses on determining the equilibrium separation in a diatomic molecule using the potential energy equation U = (A/r^12) - (B/r^6). The participant initially differentiates this equation to find the force, resulting in F(x) = (12A/r^13) + (6B/r^7), and seeks clarification on how to find the value of r that makes the force zero. After some algebraic manipulation, they conclude that the equilibrium separation is given by r = (2A/B)^(1/6). The discussion also touches on the behavior of atomic forces, noting that a larger separation results in a negative force (attractive) and a smaller separation results in a positive force (repulsive). Visualizing the potential energy function is suggested to better understand the relationship between potential energy and atomic separation.
Ginny Mac
Oh boy...this problem has stumped me. I am not even sure I know where to start:
The potential energy of a diatomic molecule (a two-atom system like H2 or O2) is given by
U= (A/r^12) - (B/r^6)
where r is the separation of the two atoms of the molecule and A and B are positive constants. This potential energy is associated with the force that binds the two atoms together.
(a) Find the equilibrium separation - that is, the distance between the atoms at which the force on each atom is zero. Is the force repulsive (atoms are pushed apart) or attractive (atoms are pulled together) if their separation is (b) smaller and (c) larger than the equilibrium separation?
Okay. I started out thinking that because we are looking for the force, we would need to use F(x) = - (d/dx)(U(x)), and after differentiation
So here is the big "now what?" Please help. Thank you - any help is greatly appreciated.
~Gin
[snip]
~Gin
You have the next step: you said "Find ... the distance between the atoms at which the force on each atom is zero." (that is, find the value of r that makes F=0)
okay...but there are three unknowns in my equation... Is there a step I am leaving out?? Even solving algebraically only reduces down to 2A-Br^6 = 0. Does something cancel out that I am not aware of? Or maybe we are supposed to be left with an equation?
You are told "A and B are positive constants". So, you can expect that your answer is in terms of those positive [but otherwise unspecified] constants.
Ahhh...so I got my equation down to (2A/B)^(1/6) = r. So that value of r is the equilibrium separation. Now for the next part, figuring out atomic behaviors based on larger/smaller values in relation to equilibrium sep. This should be interesting.
Equation: 2A-Br^6=0
If sep. is larger than equilibrium, we should have a negative force, and if it is smaller than eq., we should have a positive force. I think a negative force will draw the atoms together (?) Any thoughts are appreciated. Thank ya'll.
gin
Can you sketch the potential energy function U= (A/r^12) - (B/r^6) vs separation r, and locate your special value of r?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
