Finding the Integral of 1/((x^2+x+1))^2
  • Thread starter Thread starter jjangub
    Integral
jjangub
Show \int_{-\infty}^{\infty} 1/((x^2+x+1))^2 dx = 4\pi/(3sqrt(3))
First, I tried to find the singularities, I used (-b\pm\sqrt{b^2-4ac})/2a
so I got two singularities, but only (-b+\sqrt{b^2-4ac})/2a works.
Now, I got stuck...for 1/((x^2+x+1))^2
I tried to use the q(z)/p(z) when p(z) is two or higher degree then q(z),
we can do q(z)/p'(z). But it didn't work.
How should I do this...
I need some help...
Thank you...
When you have poles of order 2, the q(z)/p'(z) formula doesn't work; you need to go back to the main expression for residues:
res_{z_0} = \lim_{z\rightarrow z_0} \left(\frac{1}{(n-1)!}\right) \frac{d^{n-1}}{dx^{n-1}}\left[(z-z_0)^n f(z) \right]
Then you should be able to get your residues, etc.
sorry, but can you explain with other formula?
i didn't learn this formula, i instead learned an and bn to find it.
but this function is different...
Suppose you have a function f(z) which has a pole of order n at z=z_0, and you want to find the residue. Recall that the residue is the coefficient of the (z-z_0)^{-1} term of the series expansion of f(z).
Now let g(z)=(z-z_0)^n f(z). Then g is holomorphic at z_0. (Do you see why?)
But since g is holomorphic, we can write it as a power series, like so:
g(z)=\sum_{k=0}^\infty a_k (z-z_0)^k=\sum_{k=0}^\infty \frac{g^{(k)}(z_0)(z-z_0)^k}{k!}
Now we can't just go dividing by z-z_0 because it's zero, but if we take a limit, we have:
f(z) = \lim_{z\rightarrow z_0} \frac{g(z)}{(z-z_0)^n}
And since what we want is the coefficient associated with the (z-z_0)^{-1} term, we see that we have:
res_{z_0} = \lim_{z\rightarrow z_0} \frac{1}{(n-1)!} g^{(k)}
which matches the formula i posted before. But the idea is just that you expand f in a series and pull the coefficient right off the appropriate term.
well...I tried... but how do I get 3sqrt(3)?
I can't even get any roots...
some hints please...
OK, here are the steps to doing this problem (or some other problems like it). If you want more help than this, you'll need to show some work.
Step 0: Draw a big half-circle connected to the real axis with radius R.
Step 1: Show that the big half-circle part goes to zero as R goes to infinity.
Step 2: Show that the integral over the entire contour equals the quantity you are trying to find as R goes to infinity.
Step 3: Find the poles that are inside the contour.
Step 4: Find the residue at the poles, using the formula above, or whatever method you like.
Step 5: Use the residue formula to find the value of the integral over the total contour.
Step 6: Win!
I will give you this one hint: the \sqrt{3} comes from the residue calculations.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
