MHB Finding the LCM of two expressions
  • Thread starter Thread starter zolton5971
    Expressions
To find the least common denominator (LCD) of the expressions 3(2x-2) and x(5x-5), it's essential to factor each expression. The correct LCD involves identifying the highest powers of each factor present in both expressions. After simplifying, the expressions can be represented as 6(x-1) and 5x(x-1). The final LCD can be calculated by multiplying these factors together, ensuring all variables and polynomials are treated as prime factors in the process.
zolton5971
Find the least common denominator of 3(2x-2) and x(5x-)5
I wanted to double check this, I got 10 as an answer? If not how would you get the LCD?
Mathematics news on Phys.org
Do you mean $$x(5x-5)$$? You're answer should include $$x$$ somewhere
The lowest common multiple (LCM) is given by splitting each term into prime factors and multiplying by the highest power of each prime factor. For example to find the LCM of 10 and 15 (it's 30) you'd do
$$10 = 2 \times 5 \text{ and }\ 15 = 3 \times 5[/math] so the LCM is given by $$2 \times 3 \times 5 = 30$$
You can do the same with algebraic fractions but remember to treat any polynomials or variables as prime - after simplifying you have $$6(x-1)$$ and $$5x(x-1)$$
Can you use the method above to find the LCM?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
