MHB Finding the Length of a Dividing Line in a Trapezoid
The discussion focuses on calculating the length of a dividing line in a trapezoid with bases of 100m and 160m, which is parallel to the bases and divides the trapezoid into two equal areas. The participants derive a quadratic equation to express the relationship between the height and the lengths of the bases. By applying the quadratic formula, they find that the length of the dividing line, \(L\), is independent of height and is calculated as \(L = \frac{\sqrt{2(160^2 + 100^2)}}{2}\), approximating to 133.4m. A graph is provided to illustrate the division of the trapezoid into equal areas. The final result emphasizes the geometric properties of trapezoids in relation to area division.
Joe_1234
A trapezoid with a base of 100m and 160m is divided into 2 equal parts by a line parallel to the base. Find the length of dividing line.
Mathematics news on Phys.org
Hi Joe_1234, can you check and confirm if the question is correctly typed?
Do you have any idea of how to begin tackling the problem?
Let's let the larger base be \(B\), the smaller base be \(b\) and the height be \(h\).
I would consider how long a line will be that cuts the trapezoid parallel to the bases. We know this length \(L\) will decrease linearly as we move from \(0\) to \(h\), and in fact, the line will contain the points:
$$L(0)=B$$
$$L(h)=b$$
And so:
$$L(y)=\frac{b-B}{h}y+B$$
Now, we require:
$$\frac{y}{2}(B+L(y))=\frac{h}{4}(B+b)$$
$$\frac{y}{2}\left(B+\frac{b-B}{h}y+B\right)=\frac{h}{4}(B+b)$$
$$2y\left(B+\frac{b-B}{h}y+B\right)=h(B+b)$$
$$2y(2Bh+(b-B)y)=h^2(B+b)$$
Arrange as quadratic in \(y\) in standard form:
$$2(B-b)y^2-4Bhy+h^2(B+b)=0$$
Can you proceed?
$$L(0)=B$$
$$L(h)=b$$
And so:
Now, we require:
Can you proceed?
Yes. Tnx
Let's follow up...we left off with the quadratic:
Applying the quadratic formula, we find:
$$y=\frac{4Bh\pm\sqrt{(4Bh)^2-4(2(B-b))(h^2(B+b))}}{2(2(B-b))}=\frac{h(2B\pm\sqrt{2(B^2+b^2)})}{2(B-b)}$$
And so:
$$L\left(\frac{h(2B\pm\sqrt{2(B^2+b^2)})}{2(B-b)}\right)=\frac{b-B}{h}\left(\frac{h(2B\pm\sqrt{2(B^2+b^2)})}{2(B-b)}\right)+B=\pm\frac{\sqrt{2(B^2+b^2)}}{2}$$
Discarding the negative root, we obtain:
$$L(y)=\frac{\sqrt{2(B^2+b^2)}}{2}$$
As we should have expected, the result is independent of \(h\). Plugging in the given data, we find:
$$L=\frac{\sqrt{2(160^2+100^2)}}{2}\text{ m}=10\sqrt{178}\text{ m}\approx133.4\text{ m}$$
Here is a graph:
[DESMOS]{"version":7,"graph":{"viewport":{"xmin":-1,"ymin":0,"xmax":2,"ymax":1}},"randomSeed":"5f9c3ecd2c6f0225a19d7209849e7bf6","expressions":{"list":[{"type":"expression","id":"1","color":"#388c46","latex":"y=0\\left\\{0\\le x\\le1\\right\\}"},{"type":"expression","id":"2","color":"#388c46","latex":"y=h\\left\\{\\frac{1-b}{2}\\le x\\le\\frac{1+b}{2}\\right\\}"},{"type":"expression","id":"5","color":"#388c46","latex":"y=\\frac{2h}{1-b}x\\left\\{0\\le y\\le h\\right\\}"},{"type":"expression","id":"6","color":"#388c46","latex":"y=\\frac{2h}{b-1}\\left(x-1\\right)\\left\\{0\\le y\\le h\\right\\}"},{"type":"expression","id":"7","color":"#2d70b3","latex":"L=\\frac{\\sqrt{2(1+b^{2})}}{2}"},{"type":"expression","id":"8","color":"#c74440","latex":"y=\\frac{h(2-\\sqrt{2(1+b^{2})})}{2(1-b)}\\left\\{\\frac{1-L}{2}\\le x\\le\\frac{1+L}{2}\\right\\}","lineStyle":"DASHED"},{"type":"expression","id":"3","color":"#388c46","latex":"h=1","hidden":true,"slider":{"hardMin":true,"hardMax":true,"min":"0","max":"1"}},{"type":"expression","id":"4","color":"#6042a6","latex":"b=0.37","hidden":true,"slider":{"hardMin":true,"hardMax":true,"min":"0","max":".999"}},{"type":"expression","id":"9","color":"#6042a6"}]}}[/DESMOS]
Scroll down to the bottom of the expressions on the left and move the sliders. The red dashed line divides the trapezoid into two equal areas. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
