MHB Finding the log by using the proportional table
To find the logarithm of 29517, the discussion utilizes a proportional table. By referencing row 295, the value 46997 is identified, and an additional value of 11.2 is added based on the second table for the last digit. This results in a total of 47008.2, which is interpreted as 0.470082 when decimal points are considered. The final logarithm value is calculated as 4.470082, with a minor discrepancy noted when compared to a calculator's output.
cbarker1
MHB
Logarithms​
[TABLE="class: outer_border, width: 500, align: left"]
[TR]
[TD]N[/TD]
[TD]0[/TD]
[TD]1[/TD]
[TD]2[/TD]
[/TR]
[TR]
[TD]293[/TD]
[TD]46687[/TD]
[TD]46702[/TD]
[TD]46716[/TD]
[/TR]
[TR]
[TD]294[/TD]
[TD]46850[/TD]
[TD]46835[/TD]
[TD]46864[/TD]
[/TR]
[TR]
[TD]295[/TD]
[TD]46982[/TD]
[TD]46997[/TD]
[TD]47012[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Prop. Pts​
[TABLE="class: grid, width: 500, align: right"]
[TR]
[TD]1[/TD]
[TD]1.6[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]3.2[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]4.8[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]6.4[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]8.0[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]9.6[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]11.2[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]12.8[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]14.4[/TD]
[/TR]
[/TABLE]
Find the value of $\log\left({29517}\right)$
Work:
4+$\log\left({2.9517}\right)$
Thanks for your help
Mathematics news on Phys.org
Cbarker1 said:
Logarithms​
[TR]
[TD]N[/TD]
[TD]0[/TD]
[TD]1[/TD]
[TD]2[/TD]
[/TR]
[TR]
[TD]293[/TD]
[TD]46687[/TD]
[TD]46702[/TD]
[TD]46716[/TD]
[/TR]
[TR]
[TD]294[/TD]
[TD]46850[/TD]
[TD]46835[/TD]
[TD]46864[/TD]
[/TR]
[TR]
[TD]295[/TD]
[TD]46982[/TD]
[TD]46997[/TD]
[TD]47012[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Prop. Pts​
[TR]
[TD]1[/TD]
[TD]1.6[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]3.2[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]4.8[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]6.4[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]8.0[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]9.6[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]11.2[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]12.8[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]14.4[/TD]
[/TR]
[/TABLE]
Work:
Hi Cbarker1,
To find $\log(2.9517)$, we look up row $295$ in the table.
Then we pick the column with 1, where we find $46997$.
For the last digit we consult the 2nd table, where entry $7$ has $11.2$, which we add for a total of $47008.2$.
In the table the decimal points have been left out, which means we need to read this as $0.470082$.
Add the $4$ you found for a total of $4.470082$.
My calculator says $4.470072$.
Presumably the small discrepancy is an approximation error due to the use of the second table.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
