Finding the loop gain of an oscillator
To find the loop gain of an oscillator, the gain of the negative feedback component is calculated as (1 + R2/R1). The transfer function for the feedback circuit involves determining if the resistor and capacitor connected to the op-amp's '+' terminal are in series or parallel. The loop gain is expressed as (1 + R2/R1) multiplied by the feedback voltage ratio Va/Vo. When feedback is zero, the output is simply the open loop gain A multiplied by the input voltage Vi. Properly identifying the feedback configuration is crucial for accurately calculating the loop gain and understanding the circuit's behavior.
Sinister
Okay, so I know that I have to find the gain of the negative feedback part (1+ R2/R1).
But then to find the transfer function of the bottom part of the oscillator, would the resistor and capacitor that are attached to the '+' terminal of the op amp be considered in parallel?
I know that the resistor and capacitor connected directly to the output are in parallel.
L(S)=A(S)*B(S)
A(S)= (1+R2/R1)
That looks like Sedra & Smith :)
The feedback is simply the transfer function Va/Vo where Va is the voltage at the + terminal.
If you are looking at the current heading into the feedback circuit from Vo, you have (R+C)||R and that impedance is fed by the capacitor directly connected to Vo.
This is voltage / voltage feedback where the 'input' is assumed to be in series with the + lead into the op amp but is zero.
Son what will be the loop gain :s still confused if the capacitor and resistor on left side in series or parallel and how would you find B(s)
The loop gain will be (1+R2/R1)*(Va/Vo) where A=(1+R2/R1) and β=(Va/Vo)
If the feedback is zero, the output is simply A*Vi. Zero the voltage at Va to zero the feedback and imagine Vi at the Va terminal. Then your open loop gain is A=(1+R2/R1).
The feedback is voltage/voltage, meaning the output voltage is sensed and the feedback signal is a voltage subtracted from the input voltage. If the input is Vi and is in series just before the + terminal of the opamp, it is being added to the feedback signal β (so watch the sign and positive feedback condition). Then set Vi=0 for this circuit.
Edit: Adding a diagram. Circuit on left, standard feedback diagram on right. You have to match the circuit to the standard diagram.
With no feedback (Va=0), the output is Vo = A*Vi
The feedback β feeds a fraction of the output Vo to the summer (right diagram). The 'summer' (left diagram) is the series connection of Vi and Va. Note that an *addition* is happening, not a subtraction so your condition on the loop gain Aβ for positive feedback will be slightly different (ie not phase = 180 degrees)
I placed Vi like that so it wouldn't affect any part of the circuit operation. If Vi were attached at the ground end of the capacitor at Va, the feedback β would not be easily separated in the circuit. Similarly if Vi were attached at the ground end of the A part of the circuit, the feedback and open loop gain would not be easily found either.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
