Finding the mass of two metals in an alloy
To find the mass of two metals in an alloy, it's essential to consider their weights in air and water, as well as their respective volumes. The buoyancy principle can help calculate the volume based on the weight difference when submerged. It's important to note that the alloy's density may differ from the simple sum of its components, requiring adjustments in calculations. Using a mixing formula that incorporates the densities of the individual metals can yield more accurate results. Consulting a reference table for the density of the specific alloy can simplify the process significantly.
Mikiil
I need to solve this equation for homework however i do not know how.
The weight of an alloy made up of gold and silver is G=0,292N.If we submerge that alloy in water its weight becomes G=0.272N.Find the mass of the gold and the mass of the silver in the alloy.The density of gold is p=19300kg/m3 and the density of the silver is p=10500kg/m3.
G1=0,292N
G2=0.272N
p1=19300km/m3
p2=10500km/m3
m1=?
m2=?
I looked for solutions on the internet but all of them had given mass and looked for volume , but that isn't given here.
I tried something like subtracting the two weights or trying to find mass from the weight but i can't find the correct awnser
Work it backwards. If the masses are m1 and m2, what would the weight be in air? What would their volumes be? What would it weigh in water?
You can calculate the volume from the buoyancy. Then probably the assumption is made that the volume of the alloy is composed of the mixing ratio of the two parts, is a simplification because the alloy will have a greater density.
Volume(alloy)=Volume(Au)+Volume(Ag).
So set up the mixing formula and convert according to one of the volumes you are looking for and calculate.
It would be easier to search in a table book for the appropriate density of an Au-Ag alloy.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
