Finding the Mistake in Calculating Charge on a Capacitor with a Shorted Wire
  • Thread starter Thread starter Jahnavi
    Capacitor Charge
The discussion centers on a problem involving two capacitors (2μF and 3μF) shorted by a wire, with a 6V drop across a 1μF capacitor. Participants agree that the charge on the 2μF capacitor should be zero due to the short circuit, leading to confusion over the provided answer options. The consensus is that the book's answer may be incorrect since the potential across the 2μF capacitor is indeed zero. The conversation highlights the importance of understanding circuit behavior in capacitor arrangements. The conclusion emphasizes the need for clarity in textbook solutions regarding capacitor charge calculations.
Jahnavi
[/B]
Sorry for the unclear image .
There is a wire across the combination of 2μF and 3μF capacitors which means the two capacitors are shorted . The whole of 6V drops across the 1μF capacitor . In that case charge on the 2μF capacitor should be 0 . But this is not an option .
What is my mistake ?
I think it's a wrong answer by the book honestly.
Likes Jahnavi and Charles Link
You mean none of the options are correct ?
Do you agree there would be 0 charge on 2μF capacitor ?
yea because the potential across the capacitor is 0
Likes Jahnavi
Thanks !
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
