Finding the moments of a distribution
blalien
The problem is to find the moments E(X^k) of f_x(x) = (\theta+1)(1-x)^\theta, 0 < x < 1, \theta > -1
E(X^k)=\int_0^1 x^k (\theta+1)(1-x)^\theta dx
According to Mathematica, the solution is \frac{\Gamma(1+k)\Gamma(2+\theta)}{\Gamma(2+k+ \theta )}. I have no idea how to solve this integral by hand, however.
If we let W = -\log(1-x), then the distribution for W is f_w(w) = (\theta+1)e^{-(\theta+1)w}, which is just the exponential distribution. The moments are E(W^k) = \frac{\Gamma(k+1)}{(1+\theta)^k}. The question is, if we know the relation between x and w and we know the moments for w, is it possible to find the moments for x? Or is there another way to solve this integral?
Thanks in advance!
Thanks in advance!
You don't need to use Mathematica to get the value of E*W^k); it is expressible in terms of the Beta function, which is, in turn, expressible in terms of the Gamma function. The way you could do it manually is to "recognize" the Beta integral, then use standard theorems relating Beta to Gamma. Of course, if you are not familiar with the Beta integral, this will seem mysterious.
RGV
That's it, thanks. I don't know how we were ever supposed to solve this without knowing the beta function.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
