Finding the Next Collision Point in an Elastic Collision Problem
The problem involves a 0.59 kg mass colliding with a stationary 0.35 kg mass that compresses a spring, leading to a subsequent collision. To find the next collision point, one must calculate the velocities after the initial collision and determine the equations of motion for both masses. The time between the first and second collisions is crucial for locating the second collision point. The spring constant and rest length of the spring are necessary for a numerical solution, but these values are not provided, complicating the analysis. Understanding the elastic collision principles and the dynamics of the spring is essential for solving the problem.
OVB
A mass of .59 kg and a velocity of - 0.75 m/s approaches a stationary mass of 0.35 kg that is 53 cm away from the edge of a wall. The stationary (m2) pushes against a spring (elastic collision) that is within the 53cm of separation and reverses direction. How far from the end of the track does the next collision occur?
vcm = (m1v1)/M = -0.47m/s
I think i need to find the time between the first and second collisions, and then use this to find the second xcm (using the vcm I already know), relative to the first collision, and this should get me the answer, but I am not sure how to find the time it takes for the second collision.
Here is some useful background on elastic collisions.
http://hyperphysics.phy-astr.gsu.edu/hbase/colsta.html
http://hyperphysics.phy-astr.gsu.edu/hbase/elacol2.html
An elastic collision is defined as one in which both conservation of momentum and conservation of kinetic energy are observed. This implies that there is no dissipative force acting during the collision and that all of the kinetic energy of the objects before the collision is still in the form of kinetic energy afterward.
One needs to determine the velocities of each mass after the collision, then determined the equations of motion for each, and then solve for the position where the two particles meet (at the same time).
When a larger mass collides with a (smaller) mass, the large mass will continue in the same direction, assuming the collision is 'head on'. The smaller mass will rebound in the direction of the velocity large mass. In the case of the spring, the spring starts to compress which slows the second mass, until either the larger mass catches up to the smaller mass, or the smaller mass changes direction and collides with the larger mass.
To obtain a numerical solution, one needs the spring constant and rest length of the spring. Or, is the rest length of the spring 53 cm?
Oh, I understood the background info, it's the spring that's confusing me. The diagram shows it is small compared to the 53cm so I can't say what its length is. Since I don't know the k (or how to solve for it since there is no length of spring or force given) I can't determine the time between the initial collision between the smaller mass and the spring and the final release point of the mass on its way back.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
