MHB Finding the outer diameter of an annulus
  • Thread starter Thread starter linapril
    Diameter
To find the outer diameter of a pipe with an inner diameter of 28 mm and a wall cross-section area of 4.5 cm², first convert the inner diameter to centimeters, resulting in 2.8 cm. The area of the annulus is calculated by subtracting the area of the inner circle from the area of the outer circle, leading to the equation 4.5 = πr² - π(1.4)². Solving this equation for the outer radius r will yield the necessary dimensions. The final step involves doubling the outer radius to determine the outer diameter.
linapril
A pipe with a circular cross-section area has the inner diameter of 28 mm. How big should the pipe's outer diameter be, if the cross section area of the pipe's wall is 4.5 cm2?
I have been trying to solve this for ages, but failed so far... Can someone help?
Mathematics news on Phys.org
Re: Help with geometry question needed
Let's first make sure that the units are consistent. $28\text{ mm} = 2.8\text{ cm}.$
Suppose the outer radius is $r.$ The area of a cross section will be the area of the outer circle minus the area of the inner circle. So we have
\[4.5 = \pi r^2 - \pi(1.4)^2.\]
Solve for $r.$
Thank you!
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation has no solutions with positive integers if It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
