Finding the Position of a Spaceship with Given Acceleration and Velocity Vectors
Timebomb3750
Finding a position vector...
A spaceship is traveling with acceleration a(t)=<e^(t) , t , sin2t>. At t=0, the spaceship was a origin r(0)=<0,0,0> and had an initial velocity of v(0)=<1,0,0> Find the position of the ship at t=pi
uhhh...
I figured I'd work backwards with the acceleration vector given to find the velocity and position vectors, then put the t=pi into the position vector I find.
So, v(t)=<e^(t) , (1/2)t^(2) , -(1/2)cos(2t)>
Then r(t)=<e^(t), (1/6)t^(3) , -(1/4)sin(2t)>
But this doesn't seem right to me because when I put in the given t=0 into my v(t), I get <1,0,-(1/2)> not the <1,0,0> like the problem says. I'm approaching this problem wrong, aren't I?
No, you are doing fairly well. What would happen if you added a constant to the velocity?
Okay, I have it figured out.
v(t)=<e^(t) , (1/2)t^2 , (-1/2)cos(2t)+(1/2)> So that V(0)=<1,0,0>
Then, I find r(t) which is equal to <e^(t)-1 , (1/6)t^3 , (-1/4)sin(2t)+(1/2)t> So that r(0)=<0,0,0>
Then I plug in pi into my r(t) which comes out to be r(pi)=<e^(pi)-1 , (1/6)pi^3 , (pi/2)> Please tell me this is right. :)
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
