Finding the relationship between magnetic momentum and angular momentum
The discussion focuses on deriving the relationship between magnetic momentum and angular momentum for a spinning charged cylinder. Participants highlight the need to calculate magnetic momentum from both the lateral surface and the cylinder heads, emphasizing the importance of integrating over the entire surface area. There is confusion regarding the notation used for current and moment of inertia, which leads to incorrect results. The final expressions for angular momentum and magnetic momentum reveal that the relationship may depend on the charge distribution on the cylinder. Clarifications suggest that the solution simplifies if charge is only present on either the heads or the lateral surface, not both.
Argelium
A cylinder with radius ##R## and height ##h## which has a distributed charge on its surface with density ##\sigma## spins over its axis with angular velocity ##\omega##.
If the cylinder has a mass density ##\rho##, find the relationship between magnetic momentum and angular momentum.
$$L=I\omega$$
$$m_{mag}=IA$$
So my professor gave a hint that there should be no radius or height terms. However I attempted this:
First of all we must calculate two magnetic momentums, the one due to lateral surface area and another due to the cylinder heads.
For the first one consider a ##dI## on the surface area.
$$dI=\frac{dq \omega}{2\pi} = \frac{\omega\sigma}{2\pi}Rd\theta dz$$
Then the magnetic momentum of the sides is
$$m=\omega\sigma R^2h \int d\theta dz$$
$$m=\omega RhQ$$
Then for each heads we can find the magnetic momentum to be
$$\frac{1}{4}\omega R^2 Q$$
So summing them all (both vectors have the same direction: parallel to angular velocity) we obtain
$$m_{tot}= \omega R(hQ+\frac{RQ}{2}$$
Doing the calculations yields that
$$L=\frac{R}{2h+R}\frac{M}{Q} m$$
Where ##M## is the mass.
Am I missing something or is my work correct?
From the very start, you used the letter ## I ## to represent two different things. In the first way you used ## I ## it represents moment of inertia. ## I=\sum m_i r_i^2 ##. In the second case, it is electrical current, i.e. ## I=dq/dt ##. I think that caused some incorrect results. Suggestion is to get an expression for the current ## I ## in terms of ## \sigma##, ## \omega ##, ## R ##, and ## h ##. Then write an expression for the magnetic moment ## \vec{m}=IA \hat{z} ##. ## \\ ## You should also be able to write an expression for the angular momentum ## \vec{L} ##, by computing the moment of inertia for the cylinder, and then ## \vec{L}=I \omega \hat{z} ##, where ## I ## is the moment of inertia.
Ok well, I'm on mobile so that's why I wasn't very detailed (and messed up the notation, the current is ##i##, whoops)
As for the expression for the current, i don't see why it is necessary since the current is already predetermined by the charge (well ,the surface charge density and the surface area of the cylinder) and the angular velocity.
So if we take a ##di## we get it in terms of surface area (see the post for the details of my procedure) and then we integrate over the whole surface area. Now, I'm not 100% sure but to do that we must take two steps: for the lateral surface area and the top disks of the cylinder.
So once we do that two calculations of magnetic momentum (the laterals and the top and bottom) we sum them (they are parallel) and the result follows.
Summing up, my main doubt is whether calculating both the laterals and the top and bottom is what must be done (I think so since we're talking about the total surface area)
One minor, but important, oversight on my part=I overlooked the heads. For those, you need to do a ## d \vec{m}= A(r) \, \sigma \frac{2\pi r \, dr}{T } \hat{z} ##, where ## \omega=\frac{2 \pi}{T} ##, and ## A(r)=\pi r^2 ##, and integrate over ## r ##, and of course remember that there are two head surfaces. ## \\ ## Additional item: I would refrain from using the letter ## Q ##. Simply use ## \sigma ## and ## h ## and ## R ##. ## \\ ## With surface charge ## \sigma ## included on the head surfaces, I do expect the ratio you get for ## \frac{\vec{m}}{\vec{L}} ## very well might depend upon ## h ## and ## R ##. Without any surface charge on the heads, IMO, then it makes more sense to use total charge ## Q ## and total mass ##M ## and see what you get.
A follow-in: The result for angular momentum is elementary, so I will post it here: I get ## \vec{L}=\frac{1}{2} MR^2 \omega \hat{z} ##.
Using ## Q_{total \, heads} ## and ## Q_{outer \, surface } ## as parameters, (I'm going to post a result here, because that is the only way to discuss the answer I got), I get ## \vec{m}= [Q_{total \, heads} \frac{R^2 \omega}{4}+Q_{outer \, surface} \frac{R^2 \omega}{2} ]\hat{z} ##. Using ## Q_{total}=Q_{total \, heads}+Q_{outer \, surface} ##, the ## R^2 \omega ## factors out of everything, including ## \vec{L} ##, but we can not use ## Q_{total} ## in the final expression. The problem, if the hint of the professor is going to work, must either have the charge on the heads or on the outer surface, but not both at the same time. Anyway, that's what I got. Perhaps you can either confirm, or find that I made an algebraic error.
So basically what I had (and you yourself, although I have a factor of ##h## which does not appear in yours), but with the caveat that the charge in the heads is not the same charge as in the lateral (which should have been obvious). This yields a not so pretty solution. Anyways, as you said the only way the solution does not depend on the geometry of the cylinder is that there is only charge on the tops or only charge on the sides. But I think my doubts are gone! Thanks!
Likes Charles Link
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
