Finding the resultant force, moment, and x-y coordinates
j19063dc
I am trying to find help with finding the x any y coords of the resultant force, I have found the resultant force and moment but i think i may have run into problems finding the x and y coordinates. I know tha m_x' = sum Mx' but im unsure of the equation
M_x' = sum Mx', My'=sumMy'
You have missed out a step. You need to find the resultant force as a vector, not just its magnitude, before you can find the point where it acts.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
