Finding the set of u such that
  • Thread starter Thread starter 1question
    Set
To solve the inequality u(u-1) > 0, it is essential to recognize that the product is positive when both factors are either positive or negative. This leads to two cases: u > 1 (where both factors are positive) and u < 0 (where both factors are negative). The correct solution is expressed as the union of intervals (-∞, 0) U (1, ∞), indicating that u can be less than 0 or greater than 1. Understanding the distinction between "and" and "or" is crucial, as the solution cannot satisfy both conditions simultaneously. The discussion highlights the importance of analyzing the signs of the factors involved in the inequality.
1question
Hi. I'm having trouble understanding the logic behind finding a set of u for u(u-1) > 0. To solve these, I tend to factor as much as possible, then equate each expression to 0 (in this case to > 0) and solve, changing the > to < if I must divide by a negative number. I get u >0 and u > 1 but the solution is given as (-∞,0)U(1,∞), aka u>1 and u<0. Why does it say u<0?
Any help would be appreciated.
SOLVED. See below replies + http://tutorial.math.lamar.edu/Classes/Alg/SolvePolyInequalities.aspx
Mathematics news on Phys.org
This is not the correct approach. If u(u - 1) > 0 then either
1) u > 0 AND u - 1 > 0. This leads to u > 0 AND u > 1, which simplifies to u > 1
OR
2) u < 0 AND u - 1 < 0. This leads to u < 0 AND u < 1, which simplifies to u < 0
No, (-∞, 0) U (1, ∞) does not mean u > 1 and u < 0, which no number can satisfy. There is no number that is simultaneously greater than 1 and negative.
(-∞, 0) U (1, ∞) means u < 0 or u > 1. The difference between "and" and "or" here is very significant.
See above
1question said:
Hi Mark. OK, I generally understand the idea, except for why you would do 2) in the first place. The sign is > not <, so why did you do both? Thanks.
Because if a*b > 0, either both numbers have to be positive or both have to be negative. For example (-2)(-4) = + 8.
1question said:
EDIT: I believe I understand the process now.
http://tutorial.math.lamar.edu/Classes/Alg/SolvePolyInequalities.aspx is very helpful.
Alright, so what you have here Is fun.
in fact when you open the parentheses you will get: u2 - u > 0.
Now to know when that happends you can simply solve what it should look like.
since the u^2 has a positive feature you can infer it will be a "smiling" parabule.
and you can clearly see the u(u-1) You can easly infere that the whole equation will equel zero at u=0 or u=-1
look at wolf ram alpha and see the discription fits.
After this you need to look at where the Y axis (the actual u(u-1)) is larger then 0.
You will find it does at numbers higher then 1 or lower then 0.
You're approax is deviding it into 2 separate the inequalities and I believe this way is easier and quicker.
Tell me if I am unclear.
@ Spring. I figured it out already thanks to the link posted above. I appreciate the reply though!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
