Finding the Speed of a Block on a Roller Coaster
To find the speed of a block on a roller coaster at the top of a loop, the conservation of energy principle is applied, equating total mechanical energy (Emec) to kinetic energy (KE) and potential energy (PE). The relevant equation is v^2 = g(0.66H - 2R), where H is the height and R is the loop radius. Initially, the block was misidentified as a cube, but it is clarified to be a uniform solid cylinder, changing the kinetic energy calculation to account for rolling motion. The correct speed at the top of the loop is determined to be 6.00 m/s, as opposed to the initially mentioned 7.34 m/s. Understanding the moment of inertia and the relationship between angular and linear velocity is crucial for solving this problem.
iamtrojan3
A small cube (m=0.450 kg) is at a height of 393 cm up a frictionless track which has a loop of radius, R = 58.95 cm at the bottom. The cube starts from rest and slides freely down the ramp and around the loop. Find the speed of the block when it is at the top of the loop.
v^2=g (0.66H-2R)
This was one of those questions that i never understood. The final is coming up and its bothering me that i still don't no how to do this.'
The answer's 7.34m/s.
obviously the equation i tried above's not right... any help?
thanks!
its a conservation of energy problem, with only KE and PE
you know the total mechanical energy (Emec) and Emec=KE+PE=.5mv^2+mgh
oh crap posted wrong part >.<
The block's suppose to be "A uniform solid cylinder (m=0.450 kg, of small radius)" and answer's 6.00m/s. Sorry.
ok, that doesn't change the question too much.
you use the same equation as before, Emec=KE+PE, but now KE becomes the kinetic energy of a rolling object.
As you know the kinetic energy of a object moving linearly (like a block) is .5mv^2.
the kinetic energy of a rotating object is similar, .5Iw^2 (the w is supposed to be omega)
Therefore, the kinetic energy of a rolling object, one that rotates and moves is:
KE=.5mv^2+.5Iw^2
The problem is the same as before, except for the KE and the fact you know have to find the equations for moment of inertia of a solid cylinder and relate the angular velocity to linear velocity. Now, even though they don't give you the radius, if you set everything up properly, that shouldn't be a problem
I got it! i didn't know that it was still a conservation problem.
thanks a lot for the help
your welcome :smile:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
