Satvik Pandey
- 591
- 12
TSny said:Looks good.
What to do next?
Satvik Pandey said:V_A=V_C+V_A/C
V_A={\frac{MV}{m}-\frac{-lωsinθ}{2}}\hat{i} -lωcosθ/2\hat{j}.
Is it right?
What to do next?
{\frac{MV}{m}-\frac{lωsinθ}{2}}\hat{i} -lωcosθ\hat{j}.TSny said:Looks like you have a sign error in the x component. For the y component of VA did you include both the y component of VC and the y component of VA/C?
Satvik Pandey said:{\frac{MV}{m}-\frac{lωsinθ}{2}}\hat{i} -lωcosθ\hat{j}.
TSny said:That looks right.
Note that if you can find a relation between ω and V, then you will be able to express the energy equation in terms of just V. So, you will be able to solve for V.
To get a relation between ω and V, you need to use a constraint condition that you have not yet used.
To avoid messy expressions, you might want to go ahead and substitute the known values for m, M, l, and θ and simplify as much as possible your expressions for VC and VA.
I am in class 10 now.Tanya Sharma said:@Satvik :Which standard/class are you in ?
Could you explain the above expressions ?Satvik Pandey said:On putting M=5kg,m=1kg,l=1m, θ=30 and I=ml^{2}/12.
I got
[5V-\frac{ω}{48}]\hat{i}-\frac{√3 ω}{24}\hat{j}
According to wedge constraint the velocities of wedge and rod perpendicular to the to the contact surface should be same.
Velocity of wedge perpendicular to the contact surface is Vcos30
Velocity of A perpendicular to the contact surface=[5V-\frac{ω}{48}]cos150 \hat{i}-\frac{√3 ω}{24}cos60\hat{j}
Tanya Sharma said:Could you explain the above expressions ?
I got
Tanya Sharma said:How did you use I=ml^{2}/12 in the above expression ?
Satvik Pandey said:Velocity of A perpendicular to the contact surface=[5V-\frac{ω}{4}]cos150 \hat{i}-\frac{√3 ω}{2}cos60\hat{j}
So,
Vcos30=-\frac{√3}{2}[5V-\frac{ω}{4}]\hat{i}-\frac{√3 ω}{4}\hat{j}
Is it right?
Satvik Pandey said:\frac{3(√3-1)g}{2}=142V^2
V=√3(√3-1)/142
Sorry I missed that.My foolish mistakes continue.TSny said:GOT IT!
What happened to g and the factor of 2 in the denominator?
Satvik Pandey said:V=√15(√3-1)/142.
Are my other steps correct?
TSny said:Yes, everything looks good to me.
Good work!
