Comp Sci Finding the tag ID for 16-bit architecture
  • Thread starter Thread starter ver_mathstats
    Architecture Tag
The discussion centers on calculating the tag ID for a 16-bit architecture cache with 8 blocks of 32 bytes each. The initial calculations suggested 3 bits for the tag, but further analysis revealed that 8 bits are actually needed for the tag. The correct approach involves determining the block offset and index based on the total memory size and cache configuration. The participants clarified that the tag represents the upper bits of the address, while the index and offset are derived from the cache's structure. Ultimately, the consensus is that 8 bits are required for the tag in this specific architecture.
ver_mathstats
Given a DMMC 16-bit architecture, the cache holds 8 blocks of memory each being 32 bytes long, how many bits to represent the tag of each block?
offset, index, tag
I'm not sure if I am doing this right so if someone could check over my work that would be appreciated. Would we begin with 25=32 where 5 is the number of bits for the offset, then for the index it would be 256 bytes total meaning 28 so 8 bits for the index and then for the tag it would be 16-8-5=3
Is this correct? Thank you
ver_mathstats said:
Homework Statement:: Given a DMMC 16-bit architecture, the cache holds 8 blocks of memory each being 32 bytes long, how many bits to represent the tag of each block?
Relevant Equations:: offset, index, tag
Please tell us a little about the DMMC 16-bit architecture, and specifically about what the tag represents. I doubt that very many people at this site know about it.
If the tag represents the particular block in the cache, then only 3 bits are needed. But then again, I don't know what the tag is supposed to represent.
Likes ver_mathstats
A direct mapped memory cache has data stored in blocks so here we have 8 blocks. Blocks contain multiple words of data, here each block is 32 bytes long. Each block is selected by an index, the tag is the “remaining” part of the address. Index: the lower bits which is used to determine where to put the data in the cache Tag: the upper bits, this is entered into the tag field of the cache entry. Now for the formulas of how to find each: example that I found online: "A cache is direct-mapped and has 64 KB data. Each block contains 32 bytes. The address is 32 bits wide. What are the sizes of the tag, index, and block offset fields? # bits in block offset = 5 (since each block contains 2^5 bytes) # blocks in cache = 64×1024 / 32 = 2048 blocks – So # bits in index field = 11 (since there are 2^11 blocks) # bits in tag field = 32 - 5 - 11 = 16 (the rest!)"
So for my example I did the block offset as 5 because 2^5=32. As for the index I understand the example, but it throws me off in my own problem. Bc I am using this formula "Number of cache blocks = Cache size / Block size" so then 2^3 = x/2^5 solving for x we get 2^8 as for tag it is 16 (bc it is a 16 bit architecture) minus the block offset and the index. So then it would be 16-5-3=8, 8 bits for the tag after revising my answer?
I think the second time after revising my answer is the correct way to do it.
This is a classic case of distracting with extraneous information. Read the question part again: "how many bits to represent the tag of each block?"
How many blocks are there?
How do you know that?
You have the right answer in #1 but I can't see how you got there: did you cheat?
Ouch no I did not cheat, I got the first one because I did 2^5=32 again that is the block offset, 256 bytes total I got because I did 8x32, 8 blocks of 32 bytes each, so 256 bytes total then 2^8=256 which is how I got the index here then I did 16-8-5=3. This is how I did it the first time. Then I saw more examples and got confused.
Ah, I think you got it by luck then! Follow:
"I did 2^5=32 again that is the block offset" - yes,
"256 bytes total I got because I did 8x32, 8 blocks of 32 bytes each, so 256 bytes total" - yes (note 3 + 5 bits)
"then 2^8=256 which is how I got the index here" - but how do you know the index has 8 bits? You don't, you have to work backwards: if the address bus is 16 bits then the total memory is 2^16 bits and the cache size is 2^(3 + 5) bits then the index must 2^(16 - (3 + 5)) bits
"then I did 16-8-5=3" - yes
But what you have ended up with is 16 - (16 - (3 + 5)) - 5 = 3. Much easier to say "the cache holds 8 blocks of memory so I need 3 bits for the tag".
Likes ver_mathstats
hm interesting but I see now how it works, thank you
