Finding the Velocity of a Mass in Circular Motion
The discussion focuses on finding the velocity of a mass in circular motion, specifically addressing a problem involving conservation of momentum and centripetal force. The initial calculations yield a velocity of v = 2M(Lg)^(0.5)/m, which is incorrect as the expected answer is v = 4M(Lg)^(0.5)/m, indicating an error in the approach. Participants suggest reconsidering the required speed of the mass at the top of the circular path and emphasize the importance of energy conservation in the analysis. The need to account for variable centripetal force rather than assuming it is constant is also highlighted. The conversation aims to clarify the correct methodology to resolve the discrepancy in the calculated velocity.
barryj
See attached diagram and statement of problem
Conservation of momentum ...
mv = MV + mv/2
mv/2 = MV
V = mv/(2M)
centripetal force...centripetal force equals weight at top of circle.
MV^2/L = Mg
V^2 = Lg
V = (Lg)^.5
Set V = V
mv/(2M) = (Lg)^.5
v = 2M(Lg)^.5/m
The answer is supposed to be v = 4M(Lg)^.5/m
I am off by a factor of 2 where did I go wrong?
barryj said:
Set V = V
Won't M slow down as it moves from the bottom to the top?
1. What is the speed at the top of the path when the bob just barely makes it?
2. Given you answer in 1, what is the centripetal acceleration?
MV^2/L = Mg
V^2 = Lg
V = (Lg)^.5
This would be valid if the stiff rod were replaced by a string. As @kuruman noted, you need to reconsider what the required speed of M must be in order to barely make it over the top.
Likes scottdave
I think I see the error. I will fix the error and re post tomorrow.
mv = MV + mv/2
mv/2 = MV
V = mv/(2M)
MV^2/L = Mg
V^2 = Lg
V = (Lg)^.5
Set V = V
mv/(2M) = (Lg)^.5
v = 2M(Lg)^.5/m
Think, is the motion of the bob with a constant centripetal force or variable centripetal force. In all situations energy has to be conserved so why not try it out?
Likes FactChecker
