Finding the velocity of fluid through orifice
In summary: This is why your initial equation was incorrect. You had ignored the presence of a variable "g" as a result of the rotation.
Saitama
4,243
93
A horizontally oriented tube AB of length ##l## rotate with a constant angular velocity ##\omega## about a stationary axis OO' passing through the end A. The tube is filled with an ideal fluid. The end A of the tube is open, the closed end B has a very small orifice. Find the velocity of the fluid relative to the tube as a function of the column "height" h.
$$P+\rho gh+\frac{1}{2}\rho v^2=\text{constant}$$
The book I refer to states that the Bernoulli equation (stated in relevant equations) is applicable in irrotational flow. But in the given problem, the fluid rotates too. I am thinking of switching to rotating frame where the liquid moves radially so there is no problem of "irrotational flow". Is this is a valid step?
Applying Bernoulli at the open surface and near the orifice,
$$P_o=P_o+\int_{l-h}^l \rho \omega^2x\,dx+\frac{1}{2}\rho v^2$$
Solving for ##v## gives
$$v=\omega\sqrt{h^2-2hl}$$
According to the answer key, the above is incorrect. The correct answer is ##v=\omega\sqrt{2hl-h^2}##. What is wrong with my method? :confused:
Also, is it possible to find the position of CoM of remaining liquid as a function of time?
Any help is appreciated. Thanks!
Your starting equation is obviously incorrect. Cancel the ##P_0## terms, and you have that either the integral of pressure due to rotation is negative, or the square of velocity is negative. Neither can be true.
What you need to do is compare the conditions just inside and outside the orifice.
So where is the error? I mean, what's wrong with applying Bernoulli's equation at those two points?
Something like this:
$$P_o+\int_{l-h}^l\rho \omega^2x\,\,dx=P_o+\frac{1}{2}\rho v^2$$
That makes more sense.
As for the error, what two points did you have in mind? Are they possible states of the same fluid element?
Likes 1 person
I was considering two points. One on the open surface (left) and the other just on the left of orifice which is wrong. I found the error, thank you very much voko! :)
As I asked in post #1, is it possible to find the CoM of remaining liquid as a function of time?
You would need to know the area of the orifice. Given that, you can find out the volumetric rate of discharge, and with that, the amount of the remaining fluid.
Yes. This final equation looks correct. The left hand side represents the pressure inside the tube at point B (where the radial velocity in the tube is essentially zero). The right hand side represents the Bernoulli expression immediately outside the orifice. Essentially, as a result of the rotation, you have created artificial gravity within the tube, and the pressure at B is essentially hydrostatic (of course, allowing for the radially varying "gravitational acceleration."
Related to Finding the velocity of fluid through orifice
1. What is an orifice?
An orifice is a small opening or hole that is used to control the flow of fluids. It can be found in pipes, nozzles, and other equipment used in fluid systems.
2. How is the velocity of fluid through an orifice measured?
The velocity of fluid through an orifice can be measured using the Bernoulli's equation, which takes into account the pressure, velocity, and height of the fluid at different points along the flow. It can also be calculated using the continuity equation, which states that the velocity of fluid through a smaller opening will increase while the pressure decreases.
3. What factors affect the velocity of fluid through an orifice?
The velocity of fluid through an orifice is affected by the size of the orifice, the pressure of the fluid, and the properties of the fluid such as density and viscosity. Other factors such as the shape of the orifice, the flow rate, and any obstructions in the flow may also have an impact.
4. Why is it important to find the velocity of fluid through an orifice?
Finding the velocity of fluid through an orifice is important in many engineering and scientific applications. It can help determine the flow rate of a fluid, the amount of pressure needed to move the fluid through a system, and the efficiency of a fluid system. It is also crucial in designing and optimizing systems that rely on fluid flow, such as pumps, turbines, and nozzles.
5. What are some common methods used to find the velocity of fluid through an orifice?
Some common methods used to find the velocity of fluid through an orifice include using flow meters, pressure gauges, and calculation methods such as the Bernoulli's equation and the continuity equation. Advanced techniques such as laser Doppler velocimetry and particle image velocimetry may also be employed for more precise measurements.
