Finding the x component of a vector given this angle
To find the x component of a vector given an angle of 33.7 degrees, the relationship A = |A|cos33.7 can be used, leading to A = |A|0.83195. The discussion highlights the challenge of determining the unknown magnitude and x component algebraically, rather than through inefficient trial and error. It emphasizes the importance of understanding direction angles and direction cosines, where cosθ relates to the x component and the vector's magnitude. A more efficient method involves expressing cosθ in terms of x and |v|, allowing for algebraic solutions, potentially leading to a quadratic equation. Overall, the focus is on finding a systematic approach to solve for x in vector problems.
Indras
This is probably a simple question for most of you but I can't seem to figure out this format of solving a vector when there are two unknowns (Unknown magnitude and unknown x). Thank you!
V = xi + 5.9j + 9.8k
If V makes an angle with i of 33.7 degrees, what is x? x is positive
A = |A|cos33.7
A = |A|0.83195
Indras said:
Homework Statement:: This is probably a simple question for most of you but I can't seem to figure out this format of solving a vector when there are two unknowns (Unknown magnitude and unknown x). Thank you!
Relevant Equations:: V = xi + 5.9j + 9.8k
A = |A|cos33.7
A = |A|0.83195
Do you think you could find two different values of ##x## that satisfy that requirement?
Thanks!
They want the x component in decimal form. It definitely involves some algebra. For example I can solve it through process of elimination by guessing for x and solving until the magnitude divides by x and equals 0.83195.
So for this question it'd be 20.615 = √(17.15)^2 + (5.9)^2 + (9.8)^2
17.15 / 20.615 = .8319
Which gives me 33.7 degrees
But this method is definitely not efficient so there must be an algebraic method to find x more quickly?
Indras said:
Thanks!
You have ##\vec v \cdot \vec i = |\vec v| \cos \theta = \sqrt{x^2 + y^2 + z^2} \cos \theta##.
Can you find another expression for ##\vec v \cdot \vec i ##?
Likes Steve4Physics
In this question θ is called the vector's ‘direction angle’ with respect to the x-axis. And cosθ is called the ‘direction cosine’ with respect to the x-axis.
With x, y and z the components of v, the length (magnitude) of v is |v| = √(x² + y² + z²).
If you can’t draw your own, a search will give many helpful diagrams explaining (3D) direction angles/cosines.
Using your diagram, can you express cosθ in terms of x and |v|? Finding x is then just algebra (solving a quadratic).
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
