Finding theoretical impedance of acoustic transducer
Calculating the impedance of an acoustic transducer is possible if its conductance and capacitance values are known, but the configuration of these parameters (series or parallel) is crucial. Additional factors, such as inductance and the frequency range of operation, can significantly influence the actual impedance. The assumptions made by the data providers regarding resonance may also affect the analysis. A deeper understanding of the transducer's equivalent network is necessary for accurate calculations. Electromechanical acoustic circuit analysis is recommended for further exploration of these concepts.
nauman
Hi all
If we have an acoustic transducer and values of its two parameters are known, i.e conductance and capacitance, is it possible to calculate impedance using these two parameters?
Thanks
Yes.
Are those parameters in series or in parallel ?
What is the transducer equivalent network ?
nauman said:
Hi all
Thanks
It's hard to say without knowing more about your transducer. Of course we can calculate the impedance from your two parameters (after you answer @Baluncore's question), but is that the actual impedance of the transducer? I suspect that inductance matters too, it usually does. Over what frequency range? Often, if you are working away from resonance, you can ignore some parameters. The people that gave you that data may have made some assumptions about what is important. They may also have designed it to be used at resonance, in which case the resonant frequency and the capacitance will determine the dominant inductance.
So, basically, we need to know more to answer your real question.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
