Finding theta for Coloumb's law suspension
The discussion centers on calculating the angle theta for two repelling spheres suspended on strings, using Coulomb's law and Newton's second law. The participants are attempting to derive a formula to find theta based on given values: rope length of 3.0m, charge of 1.0e-4, and mass of 0.2 kg. There is confusion regarding the expected angle, with one participant calculating approximately 60 degrees, while another suggests it should be around 30 degrees based on their professor's input. The conversation hints at the possibility of needing a numerical solution rather than an analytical one, and there are suggestions to verify calculations using graphing tools. Ultimately, the participants are seeking clarity on the correct approach and expected results for the problem.
Zoidberg3001
Two spheres are suspended on strings and repel each other. Using the graphing function of your calculator setup and solve a formula to find theta.
The length of the rope is 3.0m, q = 1.0e4 and m = .2 kg.
F=k*q1*q2/r^2
Using Newton's second law I've tried several times to set up the formula to solve for theta but I am unable.
I know that the y component of tensions is equal to the force of gravity. Also that the X component of tension is equal to force caused by the repulsion of the two charges.
Equations look OK to me. Perhaps the instruction means they want you to solve numerically, not analytically ?
We were told to find the equation, set it equal to zero and plug in our given mass, charge and length then find the x intercept with a graphing calucator. I get 60 degrees which is about twice what it should be.
Can't find any givens under
[/B]​
Perhaps you can use this thread to check if your calculator works properly
(Although I admit that for the numbers at the bottom of your sheet ##\pi/3## fits a lot better than ##\pi/6## :) )
Oops, that's what I get for being in a rush. The length of the rope is 3.0m, q = 1.0e4 and m = .2 kg.
Hefty charge !
Oh jeeze I just cannot type tonight. q = 1.0e-4
Well, as I said,
So I'm at a loss. How do you know that it's not right ?
(can always try the check with this other thread to see if that fits...)
My professor said that the angle should be about 30 degrees. It's possible I misheard though. I can't find an error so I think that might be the case.
