MHB Finding Time for a Kicked Ball
  • Thread starter Thread starter balancedlamp
    Ball Time
The discussion revolves around a soccer ball's trajectory and the time it remains in the air based on given data points. The initial calculations using kinematic equations led to confusion due to incorrect assumptions about gravity and the timing of the seeker's counting. By applying a quadratic equation derived from the data points, a clearer answer of 7 seconds was obtained, suggesting the ball's time in the air is longer than initially thought. The discrepancy arose from misinterpreting the seeker's counting rate and the local gravitational acceleration. Ultimately, the problem highlights the importance of accurately interpreting the parameters in physics equations.
balancedlamp
Problem: You are playing soccer with some friends while some people nearby are playing hide and seek. When the seeker gets to '4', you kick the soccer ball high in the air. WHen the seeker says '5', the ball is 10 ft in the air. When the seeker gets to '7', the ball is 20 feet in the air. How many seconds will the ball be in the air in total before it hits the ground?
Given that after 1 second the ball traveled 10 ft in the air, I had the initial velocity as 10 ft/s. At the apex, the velocity will be 0 ft/s. Since change in position is not given I used the equation Vf = Vi + at. My thought was to find the time this way then multiply by two. Using a=-32.2 ft/s/s, I got t=5/8 s at the end of it all, which doesn't make any sense. I acknowledge that I left out the part about it being 20ft in the air after 2 seconds, but I thought that would erroneous considering we know the initial velocity and the value of a. What am I doing wrong?
Mathematics news on Phys.org
In my opinion,the problem is either bogus or the setting of the problem isn't on Earth's surface.
You are given 3 data points (t,h), where t is time in seconds and h is in ft ...
(0,0) , (1,10) , (3,20)
those three data points yield the quadratic $h = \dfrac{35}{3} \cdot t - \dfrac{5}{3} \cdot t^2$
if done on Earth,the equation should be $h = v_0 \cdot t - 16t^2$
Perhaps the 'seeker' calls the time every 3 seconds or so?
Once I approached it using the three points and finding the quadratic equation, I just plugged it into a graphing calculator and got the answer of 7 seconds, which is one of the answer choices.
However, I'm confused why the kinematic equations are giving me such funky answers, while the quadratic equation is pretty straightforward. Was my approach using the initial kinematic equation wrong?
You say you used "
a=-32.2 ft/s/s" but, as skeeter said, that, the Earth's acceleration due to gravity, does not give the data in the problem. With the given data, the acceleration due to gravity, wherever this is, is \frac{10}{3} feet per second per second, not 32.2 feet per second per second.
Or, as Klaas van Aarsen points out, the problem does not actually say that the person calling numbers calls one per second. Taking the trajectory to be (35/3)x- (5/3)x^2 then \frac{5}{3}x^2= 16.1 t^2 if x^2= \frac{48.3}{5}t^2 so that x= \sqrt{\frac{48.3}{5}}t= \sqrt{9.66}t= 1.932 t so that the person was calling numbers every 1.932 seconds or approximately every 2 seconds, not every three seconds.
Of course, that would change the answer. If the ball was in the air for x= 7 "units" then it is in the are for 7(1/932)= <span style="font-family: 'Verdana'">13.524</span> seconds, approximately 14 seconds.
My apologies, according to the problem, the seeker counts at a rate of 1 whole number per second. Sorry for leaving that out, that was completely accidental.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
