MHB Finding Triples of Positive Integers in Power Equations
  • Thread starter Thread starter anemone
For a given positive integer p, the problem seeks triples (q, x, y) of positive integers where q is relatively prime to p, satisfying the equation (x^2 + y^2)^p = (xy)^q. It is established that if a pth power is also a qth power, it must be a pqth power, leading to the requirement that q must be greater than p. The derived equations indicate that the only solution occurs when q = p + 1 and both x and y equal 2^(p/2), necessitating that p be even. For odd values of p, no solutions exist.
anemone
MHB
POTW Director
For a given positive integer $p$, find all triples $(q,\,x,\,y)$ of positive integers, with $q$ relatively prime to $p$, which satisfy $(x^2+y^2)^p=(xy)^q$.
Mathematics news on Phys.org
[sp]If a $p$th power is also a $q$th power (with $p$ and $q$ relatively prime), then it must be a $pq$th power. So if $(x^2+y^2)^p=(xy)^q$, then there must be some integer $z$ with $x^2+y^2 = z^q$ and $xy = z^p.$ Solving the second of those equations for $y$ and substituting that into the first equation, you get $$x^2 + \frac{z^{2p}}{x^p} = z^q.$$ Therefore $x^4 - z^qx^2 + z^{2p} = 0,$ a quadratic in $x^2$ with solutions $x^2 = \frac12\bigl(z^q \pm\sqrt{z^{2q} - 4z^{2p}}\bigr).$ For the expression in the square root to be non-negative, we must have $q>p$, so that $x^2 = \frac12\bigl(z^q \pm z^p\sqrt{z^{2(q-p)} - 4}\bigr).$ But the only way for two squares to differ by $4$ is if they are $4$ and $0$. Therefore $z^{2(q-p)} = 4$, from which $q = p+1$ and $z=2$. The solution is then $q= p+1$, $x=y=2^{p/2}$, which implies that $p$ must be even. For odd $p$ there is no solution.[/sp]
Opalg said:
[sp]If a $p$th power is also a $q$th power (with $p$ and $q$ relatively prime), then it must be a $pq$th power. So if $(x^2+y^2)^p=(xy)^q$, then there must be some integer $z$ with $x^2+y^2 = z^q$ and $xy = z^p.$ Solving the second of those equations for $y$ and substituting that into the first equation, you get $$x^2 + \frac{z^{2p}}{x^p} = z^q.$$ Therefore $x^4 - z^qx^2 + z^{2p} = 0,$ a quadratic in $x^2$ with solutions $x^2 = \frac12\bigl(z^q \pm\sqrt{z^{2q} - 4z^{2p}}\bigr).$ For the expression in the square root to be non-negative, we must have $q>p$, so that $x^2 = \frac12\bigl(z^q \pm z^{2p}\sqrt{z^{2(q-p)} - 4}\bigr).$ But the only way for two squares to differ by $4$ is if they are $4$ and $0$. Therefore $z^{2(q-p)} = 4$, from which $q = p+1$ and $z=2$. The solution is then $q= p+1$, $x=y=2^{p/2}$, which implies that $p$ must be even. For odd $p$ there is no solution.[/sp]
What a perfect and brilliant solution, Opalg! (Happy)
Well done and thanks for participating! :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
