Finding Values of Complex Equation
ver_mathstats
Find the values of ((1-i)/sqrt(2)) ^ (i+1)
I took the equation and rewrote it as: e(i+1)(log(1-i)-log(√2)).
So I worked on it in sections meaning e(i+1) and then log(1-i).
For e(i+1) I got eie1 and used Euler's formula for ei to get: e1(cos(1)+isin(1)).
And then for log(1-i) I got ln√2 + i(-(π/4)+2kπ).
Do I just bring them together now? Or would I first FOIL the exponent at the very beginning as in this part "(i+1)(log(1-i)-log(√2))"? Any help would be appreciated thank you!
ver_mathstats said:
Relevant Equations:: ((1-i)/sqrt(2)) ^ (i+1)
I take it
[e^{-\frac{\pi i}{4}}]^1 [e^{-\frac{\pi i}{4}}]^i
Does this work ?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
