Finding weight with force and theta
In summary, when the force directed along the leg is 26.0N, W must be equal to 24.4N. To find this, the two angles must be considered and the tension in the two sections of string must be resolved into components along the x and y-axis. All four sections of the string have the same tension.
k2var2002
What must W be when the force directed along the leg is 26.0N
http://session.masteringphysics.com/problemAsset/1012378/6/image5.42.jpg
[tex]\Sigma[/tex]F=ma=mg
I used the two angles and drew the y-axis down from the top downward segment to form "two" right triangles. I considered downward on the y-axis to be positive. And finally combined the two angles(70) and took 26sin(70)= 24.4N
Any suggestions would be greatly appreciated.
Your calculation is wrong.
Consider the tension in the two sections of the string be T, which is equal to mg. Resolve these tensions into two components along x and y-axis and proceed.
What are the two strings that I should account for with accompanied tension?
Since string is contentious, tension in all four sections is the same. Here you have to consider the tension in the section of string between two pulleys.
FAQ: Finding weight with force and theta
What is the formula for finding weight with force and theta?
The formula for finding weight with force and theta is weight = force * cos(theta). This formula takes into account the angle at which the force is applied, as well as the magnitude of the force itself.
How do I measure the force and theta in order to find weight?
To measure the force, you will need a force meter or scale. The theta angle can be measured using a protractor or by using a trigonometry calculator. Make sure to measure the angle relative to the horizontal plane.
Can I use this formula for any object?
Yes, this formula can be used for any object as long as the force is applied at a single point and the object is not in motion. It is important to note that the weight calculated using this formula is the weight of the object at rest, not in motion.
How does the angle theta affect the weight of an object?
The angle theta affects the weight of an object because it changes the direction of the force being applied. The weight calculated using this formula takes into account the component of the force that is acting in the downward direction, which is affected by the angle theta.
Is there a difference between weight and mass when using this formula?
Yes, there is a difference between weight and mass when using this formula. Weight is a measure of the force of gravity acting on an object, while mass is a measure of the amount of matter in an object. This formula calculates weight, not mass.
