Python FineTune the Pixel2Style2Pixel model with my custom data set
The discussion revolves around troubleshooting an error encountered while fine-tuning the Pixel2Style2Pixel (pSp) model with a custom dataset. The user initially faced an "AttributeError" indicating that the 'CustompSp' object lacked a 'device' attribute. This was traced back to the fact that the parent class, pSp, did not define a device attribute. The solution involved modifying the CustompSp class to include a device attribute, which was successfully implemented. After this adjustment, the model was able to load the pre-trained weights without further issues, indicating that the modification resolved the error. The conversation highlights the importance of checking class attributes when debugging inheritance issues in Python.
btb4198
I want to fine-tune the Pixel2Style2Pixel model with my custom data set, but I keep getting an error when I'm trying to load in the pre-train weights. Here is my code :
[CODE lang="python" title="fine-tune the Pixel2Style2Pixel model"]# Load the pre-trained model
os.chdir("/content/pixel2style2pixel")
from models.psp import pSp
config = {
"lr": 0.0001,
"betas": (0.9, 0.999),
"weight_decay": 1e-6,
"stylegan_size": 1024,
"checkpoint_path": MODEL_PATH,
"device": DEVICE,
"input_nc": 3, # Assuming 3 input channels
"output_size": 256, # Add the missing attribute
"encoder_type": 'GradualStyleEncoder', # Add the missing attribute
config["checkpoint_path"] = "/content/pixel2style2pixel/pretrained_models/psp_ffhq_encode.pt"
updated_config = config.copy()
updated_config['n_styles'] = 16
config_object = SimpleNamespace(**updated_config)
from pixel2style2pixel.models.psp import pSp
def get_keys(d, name):
if 'state_dict' in d:
d = d['state_dict']
d_filt = {k[len(name) + 1:]: v for k, v in d.items() if k.startswith(name)}
return d_filt
class CustompSp(pSp):
def __init__(self, opts):
super().__init__(opts)
self.device = torch.device('cuda' if torch.cuda.is_available() else 'cpu')
def load_weights(self):
ckpt = torch.load(self.opts.checkpoint_path, map_location=self.device)
filtered_state_dict = {k: v for k, v in ckpt['state_dict'].items() if 'encoder' in k}
self.encoder.load_state_dict(filtered_state_dict, strict=False)
decoder_state_dict = {k.replace('module.', ''): v for k, v in ckpt['state_dict'].items() if 'decoder' in k}
self.decoder.load_state_dict(decoder_state_dict, strict=False)
self.load_latent_avg(ckpt)
def load_latent_avg(self, ckpt):
if 'latent_avg' in ckpt:
self.latent_avg = ckpt['latent_avg'].to(self.device)
else:
self.latent_avg = None
model = CustompSp(config_object)
model.train()
model.to(DEVICE)[/CODE]I am getting this error: AttributeError: 'CustompSp' object has no attribute 'device'
[CODE title="Full error message"]---------------------------------------------------------------------------
AttributeError Traceback (most recent call last)
<ipython-input-71-36ef46aa58b7> in <cell line: 1>()
----> 1 model = CustompSp(config_object)
2 model.train()
3 model.to(DEVICE)
3 frames
/usr/local/lib/python3.9/dist-packages/torch/nn/modules/module.py in __getattr__(self, name)
1612 if name in modules:
1613 return modules[name]
-> 1614 raise AttributeError("'{}' object has no attribute '{}'".format(
1615 type(self).__name__, name))
1616
AttributeError: 'CustompSp' object has no attribute 'device'[/CODE]
Technology news on Phys.org
Your custompSp class inherits from the pSp class. Does the pSp class (which isn't shown in the code you provided) have a device attribute?
Sorry, I am posting it now:
[CODE title="psp.py"]"""
This file defines the core research contribution
import matplotlib
matplotlib.use('Agg')
import math
import torch
from torch import nn
from models.encoders import psp_encoders
from models.stylegan2.model import Generator
from configs.paths_config import model_pathsdef get_keys(d, name):
d = d['state_dict']
d_filt = {k[len(name) + 1:]: v for k, v in d.items() if k[:len(name)] == name}
return d_filtclass pSp(nn.Module):
super(pSp, self).__init__()
self.set_opts(opts)
# compute number of style inputs based on the output resolution
self.opts.n_styles = int(math.log(self.opts.output_size, 2)) * 2 - 2
# Define architecture
self.encoder = self.set_encoder()
self.decoder = Generator(self.opts.output_size, 512, 8)
self.face_pool = torch.nn.AdaptiveAvgPool2d((256, 256))
# Load weights if needed
self.load_weights()
def set_encoder(self):
if self.opts.encoder_type == 'GradualStyleEncoder':
encoder = psp_encoders.GradualStyleEncoder(50, 'ir_se', self.opts)
elif self.opts.encoder_type == 'BackboneEncoderUsingLastLayerIntoW':
encoder = psp_encoders.BackboneEncoderUsingLastLayerIntoW(50, 'ir_se', self.opts)
elif self.opts.encoder_type == 'BackboneEncoderUsingLastLayerIntoWPlus':
encoder = psp_encoders.BackboneEncoderUsingLastLayerIntoWPlus(50, 'ir_se', self.opts)
else:
raise Exception('{} is not a valid encoders'.format(self.opts.encoder_type))
return encoder
if self.opts.checkpoint_path is not None:
print('Loading pSp from checkpoint: {}'.format(self.opts.checkpoint_path))
ckpt = torch.load(self.opts.checkpoint_path, map_location='cpu')
self.encoder.load_state_dict(get_keys(ckpt, 'encoder'), strict=True)
self.decoder.load_state_dict(get_keys(ckpt, 'decoder'), strict=True)
self.__load_latent_avg(ckpt)
else:
print('Loading encoders weights from irse50!')
encoder_ckpt = torch.load(model_paths['ir_se50'])
# if input to encoder is not an RGB image, do not load the input layer weights
if self.opts.label_nc != 0:
encoder_ckpt = {k: v for k, v in encoder_ckpt.items() if "input_layer" not in k}
self.encoder.load_state_dict(encoder_ckpt, strict=False)
print('Loading decoder weights from pretrained!')
ckpt = torch.load(self.opts.stylegan_weights)
self.decoder.load_state_dict(ckpt['g_ema'], strict=False)
if self.opts.learn_in_w:
self.__load_latent_avg(ckpt, repeat=1)
else:
self.__load_latent_avg(ckpt, repeat=self.opts.n_styles)
def forward(self, x, resize=True, latent_mask=None, input_code=False, randomize_noise=True,
inject_latent=None, return_latents=False, alpha=None):
if input_code:
codes = x
else:
codes = self.encoder(x)
# normalize with respect to the center of an average face
if self.opts.start_from_latent_avg:
codes = codes + self.latent_avg.repeat(codes.shape[0], 1)
else:
codes = codes + self.latent_avg.repeat(codes.shape[0], 1, 1) if latent_mask is not None:
for i in latent_mask:
if inject_latent is not None:
if alpha is not None:
codes[:, i] = alpha * inject_latent[:, i] + (1 - alpha) * codes[:, i]
else:
codes[:, i] = inject_latent[:, i]
else:
codes[:, i] = 0
input_is_latent = not input_code
images, result_latent = self.decoder([codes],
input_is_latent=input_is_latent,
randomize_noise=randomize_noise,
return_latents=return_latents)
if resize:
images = self.face_pool(images)
if return_latents:
return images, result_latent
else:
return images
def set_opts(self, opts):
self.opts = opts
def __load_latent_avg(self, ckpt, repeat=None):
self.latent_avg = ckpt['latent_avg'].to(self.opts.device)
if repeat is not None:
self.latent_avg = self.latent_avg.repeat(repeat, 1)
else:
self.latent_avg = None[/CODE]
You are correct that the pSp class does not have a device attribute. So I modify the CustompSp class by adding a device attribute as follows:
[CODE title="updated CustompSp class"]class CustompSp(pSp):
else:
[/CODE]Anyhow it seemed to work
I didn't say that the pSp class was missing a device attribute. I just asked whether the pSp class had such an attribute. If you get an error that such-and-such attribute is missing, an obvious thing to do is to see if that attribute is present in the class or any super class.
What a surprise...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
