- #71
Cuetek
- 47
twofish-quant said:What I'm saying is you are basically misinterpreting how astrophysicists think.
1) The cosmological principle is not some sort of dogma, but a guess and a rough rule that allows people to make calculations
2) Without data, it's impossible to make firm statements about whether it is globally true or not. It *is* possible with the current data to say that assuming the cosmological principle allows us to make predictions about the universe that seem to accord with observations.
You are being very circumspect with the above characterization. However, when I hear cosmologist being interviewed, they say without qualification things like "if the universe is convext it will expand forever, if it is flat it will reach a steady state (or something like that) and if it's concave it will recollapse." These are reflexive predictions typical yet presumptuous beyond your above characterization. I say the reflex runs deeper than you think and that it is counter productive to a more realistic view of the proper extent and configuration of the universe.
It's no big deal. The data will tell the tale. But it may take longer.
twofish-quant said:Right, because you can then take the model and make predictions about the universe. The point that I'm making is that just because an astrophysicist makes an assumption in a model, doesn't mean that they think that assumption is true. If you want to *disprove* the cosmological principle, then what you need to do is to create a model that *assumes* that the principle is true, show that that model inherently creates results that don't match observations.
In essense, that's what I've done. I show a statistical probability that the universe will not conform to the cosmological principle and I make a prediction that the CMB will show evidence of inhomogeneity.
twofish-quant said:The highly developed math is because it is a really, really painful and difficult thing to go from theory to observational test. Suppose you were to assert that the density of the universe falls off very strongly an 2x the observational horizon. Going from that assumption to COBE power spectrum measurements is extremely painful.
Which is exactly the approach you need to take if you doubt that it is true. Let's assume that the cosmological principle is false. You predict X. You see X. That tells you absolutely nothing. So let's assume that the cosmological principle is true. You predict X. You see not-X. At this point the cosmological principle is proven wrong.
If you were seeing increases in the power spectrum at higher and higher scales, then we'd have a big problem. If there were systematic differences in the CMB in different parts of the sky, we'd have a big problem. You *assume* something is true, so that you have some idea what to look for in order to prove that it is false.
I'm assuming that the universe is more likely hierarchical than homogeous. I predict very slight variations on opposite sides of the sky due to my prediction that they big bang is finite in extent causing a slightly higher CMB temp and material density in the direction of it's "center". That we don't have the data yet is not being debated. My predictions, like many, will have to wait to be confirmed or refuted.
twofish-quant said:Why? I make statements about what the world looks like 10^6 times the particle horizon and that see if it makes any difference.
It will make no difference to your idealized model, But the farther away you make your characterizations the less coroborable they are. I probably don't really see what you are saying here.
twofish-quant said:Why? What you really need to do is to make a million different hypothesis and then throw them against the wall to see what sticks.
Well, I've made one, we'll see if it sticks. May take a while.
twofish-quant said:Which is what people have done.
I predict they will find what they are looking for. But only a few people are trying very hard to find something contratry to the CP. Most people are trying to confirm it.
twofish-quant said:What I'm saying is that I think you are misinterpreting what theorists are doing. Most papers in cosmology have nothing to do with the ultra-large scale structure of the universe, so there people assume the cosmological principle because the math is simpler, and if what you are doing isn't impacted by the ultra-large scale structure of the universe, you want to assume spherical cows and flat Earth's. Most papers in astrophysics outside of very narrow fields use Newtonian gravity because GR is just a pain to calculate.
If you are *expecting inhomogenity* then you assume homogenity. At that point you write papers invoking the cosmological principle, figure out the implications, and the look for deviations from observations. The problem with create models of inhomogenity is that once you've done that, you've restricted yourself to a particular model, which causes problems if both the CP and the inhomogenous model is wrong.
If you want to kill the CP, you need to absolutely avoid presenting an alternative model, and you need to focus on writing papers that assume the CP is true.
Also you be careful not to extrapolate someone's beliefs from the papers that they write. I don't know whether the CP is correct or not, but I'd certainly be depressed if it where.
I don't think I am overestimating how strongly most cosmologists believe that it is perfectly plausible that the universe is intirely homogeneous at the largest visible scales. I know that all good scientists will say that they don't know, but the what they look for in their work is a better indication of what they believe and that is confirmation of the CP for the most part.
I say that there is a strong tendency for all of us to prefer a presumption that makes the whole universe comprehensible under the current data set and assumptions. By making whatever is out there conform to the same disposition as what we can see of it, we have inadvertently limited our conception of the universe in a way that I feel is counter productive to discovering the wider truth.
It'm not refuting anything. I'm only trying to reveal the conceptual downside of CP. It's not an affront to science, but it can seem like an affont to our abilibty to ever know the whole truth. Some people find that more depressing than you find the ultimate implication of the CP.
