Finite Dimensional Division Algebras - Bresar Lemma 1.1
In summary, the conversation discusses the proof of Lemma 1.1 in Matej Bresar's book "Introduction to Noncommutative Algebra." The discussion centers around the linear dependence of elements in a finite dimensional division algebra and how it leads to the existence of a non-zero polynomial of degree at most n such that f(x) = 0. The conversation concludes with a clarification of the variable names used in the proof.
Math Amateur
MHB
3,998
48
I am reading Matej Bresar's book, "Introduction to Noncommutative Algebra" and am currently focussed on Chapter 1: Finite Dimensional Division Algebras ... ...
I need help with the an aspect of the proof of Lemma 1.1 ... ...
Lemma 1.1 reads as follows:
In the above text, at the start of the proof of Lemma 1.1, Bresar writes the following:
" ... ... Since the dimension of ##D## is ##n##, the elements ##1, x, \ ... \ ... \ , x^n## are linearly dependent. This means that there exists a non-zero polynomial ##f( \omega ) \in \mathbb{R} [ \omega ]## of degree at most ##n## such that ##f(x) = 0## ... ... "My question is as follows:
How exactly (rigorously and formally) does the elements ##1, x, \ ... \ ... \ , x^n## being linearly dependent allow us to conclude that there exists a non-zero polynomial ##f( \omega ) \in \mathbb{R} [ \omega ]## of degree at most ##n## such that ##f(x) = 0## ... ?Help will be much appreciated ...
Peter
=====================================================In order for readers of the above post to appreciate the context of the post I am providing pages 1-2 of Bresar ... as follows ...
This follows from the definition of linear independence (or dependence). You may want to remind yourself of that definition and write down exactly what it means in this case.
Thanks zinq ... but I need some further help ... ...
The linear dependence of the elements ##1, x, \ ... \ ... \ , x^n## meas that we can find elements ##c_0, c_1, \ ... \ ... \ , c_n \in \mathbb{R}## , not all zero, so that:
##c_0.1.+ c_1.x + \ ... \ ... \ + c_n x^n = 0##
BUT ... how do we proceed to demonstrate that this implies that there exists a non-zero polynomial ##f( \omega ) \in \mathbb{R} [ \omega ]## of degree at most ##n## such that ##f(x) = 0## ... ...
Can you help further ... ?
Peter
We take ##f(x)=0## by construction of ##c_i## as the a non-trivial linear combination ##0=c_0 \cdot 1 + c_1 \cdot x + \ldots + c_n x^n## which must exist for dimensional reasons.
Then we define ##f(\omega) := c_0 \cdot 1 + c_1 \cdot \omega + \ldots + c_n \cdot \omega^n##, i.e. ##f(\omega) \in \mathbb{R}[\omega]## and ##f(\omega) \leftrightarrow (c_0 , c_1 , \ldots , c_n) \neq 0## because we have more "vectors" ##(1,x,\ldots,x^n)## than the dimension ##n##.
Btw.: Funny choice of variable names. Usually ##x## is the indeterminate and ##\omega## a number. Here it's the other way around.
Likes Math Amateur
Thanks fresh_42 ... clear and helpful ...
Appreciate your help ...
Peter
Related to Finite Dimensional Division Algebras - Bresar Lemma 1.1
1. What is the Bresar Lemma 1.1 in Finite Dimensional Division Algebras?
The Bresar Lemma 1.1 is a result in the field of algebraic structures known as finite dimensional division algebras. It states that for any finite dimensional division algebra, there exists a subalgebra that is isomorphic to a finite dimensional division algebra of the same dimension.
2. Why is the Bresar Lemma 1.1 important in the study of Finite Dimensional Division Algebras?
The Bresar Lemma 1.1 is important because it shows that every finite dimensional division algebra can be reduced to a simpler and more manageable form. This can help in understanding the properties and structures of division algebras, and can also be useful in solving problems related to them.
3. What is a division algebra?
A division algebra is an algebraic structure in which every non-zero element has a multiplicative inverse. This means that for any two elements in the algebra, there exists another element that when multiplied with either of them, results in the identity element. In simpler terms, it is a type of algebra where division is always possible.
4. What are the applications of Finite Dimensional Division Algebras?
Finite Dimensional Division Algebras have applications in various fields, including physics, engineering, and computer science. They are used in the study of rotations and reflections in 3-dimensional space, and in the construction of error-correcting codes in computer science. They also have applications in quantum mechanics and abstract algebra.
5. Can the Bresar Lemma 1.1 be extended to infinite dimensional division algebras?
No, the Bresar Lemma 1.1 only applies to finite dimensional division algebras. In infinite dimensions, there are counterexamples that violate the lemma. However, there are similar results that hold for infinite dimensional division algebras, such as the Artin-Wedderburn theorem which states that every finite dimensional central simple algebra is isomorphic to a matrix algebra over a division ring.
  • Linear and Abstract Algebra
